944-SPEC '88 924S Track/DE/Autox Car (SoCal)
1988 Porsche 924S. Fully prepped, running, ready to race (just add window and right-side net). Car has never been “raced.” Mainly used for auto-x and the occasional DE. Title in hand, and car is registered (CA) until 6/20/12.
$7,000 OBO ($7,500 with spares)
Located in Orange, CA
Contact Chris: [email protected]
You can see the build here: http://www.cryogenicsmedia.com/Porsche
You can see videos of the car in action here: http://www.youtube.com/user/barringTRON?feature=mhee
Heres the modification and replacement list
Chassis- 1988 924S (10.2:1 compression engine, short 5th gear)
Front Suspension
Ground Control coilover kit
400# hypercoil 8 inch springs
Ground Control Camber plates
Weltmeister caster block control arm bushings
Delrin front control arm bushings
Koni yellow dampeners (replaced in 2008)
Upper strut tie-bar
27mm M030 swaybar
Poly inner sway bar bushings
Hawk HP+ brake pads
Rear Suspension
Sway-a-way 30mm Torsion Bars
Koni yellow shocks (replaced in 2010)
Weltmeister inner and outer poly spring plate bushings
Weltmeister inner and outer poly Torsion bar bushings
22mm adjustable Weltmeister sway bar
Street brake pads
Axles rebuilt in 2007
Stage8 locking axles bolts
Engine
1988 engine, 165k miles
Rod bearings replaced in 2007
Motor mounts in 2007
AC delete bracket
951 oil cooler
6 blade radiator fans hooked up to manual switches
Replaced all radiator hoses
Engine undertray
Tubular 88 Headers
Custom exhaust with Magnaflow muffler (no cat)
Stock airbox (plus cone air filter to swap if you wish)
Coolant expansion tank replaced in 2011
Clutch replaced in 2011
Timing belt, front engine seals and water pump replaced in 2011
Remanufactured head installed in Feb. 2012
Safety
Sparco Circuit halo seat $$$ (contact me to see if it will fit you)
Sparco seat slider
Momo steering wheel
Momo hub adaptor
Quick release for steering wheel
Custom, professionally built, roll cage with dash bar(by Pierce Motorsports)
SFI roll bar padding
NASCAR drivers-side door bars
X-style passenger side door bars
Dash bar OVER the steering column
Sparco 6 point camlock harness
10BC fire extinguisher mounted to dash bar
Power kill switch with cable
Interior
Gutted, stripped, cleaned and painted
Panoramic mirror
Oil pressure gauge
Oil temperature gauge
Voltage gauge
Redundant water temp gauge (sender needs to be replaced)
Exterior
Painted in 2009
No major dings or dents
Minor scuffs and blemishes (it is a track car after all)
Front and rear tow hooks
New windshield (Aug 2012)
Other
Car weighs approx.. 2500 pounds
15lb motorcycle battery
Power steering has been “de-powered” to emulate manual rack
4 15 x 7 phone dials with 225/45/15 NT01s (I know they’re not spec legal, but they only have one DE on them)
4 15 x 6 phone dials with tires for towing.
Spares
84 engine (short block) with good bores
88 head
84 cam tower
88 DME (getting hard to find)
Fuel pump relay
4 15x7 phone dials (painted, no tires)
New control arm
Alternator belt
Coolant hose
New front rotors (zero miles)
New Hawk Blue front brake pads (zero miles)
