Japelle Posted August 16, 2012 Share Posted August 16, 2012 Does anyone know which wire I tap into in order to get a signal pulse for my tach? I'm trying to tie it into my Traqmate. I purchased an MSD GMR pickup and got it working (once in the garage) however once I got on the track it went out. Any help and photos will be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
laze1 Posted August 16, 2012 Share Posted August 16, 2012 I have mine hooked up...when I get home I will get some pics and info...it may be this weekend...will that work? I do know that the placement of the pickup on the wire is critical...how loose/tight you connect can cause problems Quote Link to comment Share on other sites More sharing options...
Japelle Posted August 16, 2012 Author Share Posted August 16, 2012 That will work. Thanks! Quote Link to comment Share on other sites More sharing options...
laze1 Posted August 25, 2012 Share Posted August 25, 2012 crappy cell phone picture ...but I think you are wired the same as I am... I am connected to the black wire with a grey spot on it going to the coil. If you are getting intermittent signal, readjust your clamp. Quote Link to comment Share on other sites More sharing options...
