1996 Turbo Miata Trackcar
This is an ultimate feeler thread.
Thinking about changing things up drastically!
For Sale: Wont part out so don’t ask, unless I have people that want everything!
Chassis:
Clean WI title in hand
Can be driven on the street (if no emissions are required)
Would be a crazy fun DD
Cleanest Miata chassis I've ever seen
1996 Mazda Miata
58K Original Miles
Power windows/ mirrors
Original LSD car with 4:11’s
Engine:
58K miles on motor
2k miles (max) on turbo setup
300hp @ 13psi
Bell Engineering S4 Kit (this is a full kit, only thing you need is new studs for the manifold)
About 5000 miles on turbo itself
#3 Intercooler
GT2871R
3” diverted gases dp
All SS lines
Big oil cooler
550cc pnp injectors
PNP megasquirt,
Full 3” Entuzacar exhaust, no mufflers just one resonator
Innovate Wideband
Autometer boost gauge, oil pressure gauges
Accutech oil temp, coolant temp gauges
2 gauge a-pillar pod
Koyo 37mm radiator
949 coolant re-rout
Trans:
58K miles
5 speed
Lightweight aluminum flywheel and race clutch
No grinds, shifts like the day I got the car
Suspension:
Bilstein spec miata shocks
Eibach springs
Eibach front sway bar
Full poly bushings
Brand new wheel bearings all around
Brakes/Wheels:
11.75” Trackspeed Engineering BBK
4 piston Wilwoods front
11” rear sport rotors
Stock rear calipers
Hawk DTC-60’s
Wilwood proportioning valve
15x10 6ULS with 245/580R15 slicks
15x7 RPF1s with old 205/50/15 R6’s
Body:
BRAND NEW montego blue paint
Car has been flared about 2” by pulling factory fenders
Custom cutout on hood
Custom front splitter
Carbon fiber hardtop
Kognition wing
Safety/interior:
Interior is stock minus carpet removed
Bolt in 6-point cage
Sparco Circuit seat
17” Ultrashield Seat
G-force belts
Traqmate
Sparco suede wheel
Quick release
Extras:
Car will come with everything I have.
I have every part to turn this car back to stock minus shocks
Will come with seats/ brakes/ ecu/ exhaust/ ect…
The car is an absolute rocket and deserves a good home.
It would even be faster with a better shock package. Easily low 2:30's at Road America.
Car ran consistent 2:38's last month, very hot and humid day only making 10psi
Again this is a feeler, looking to get $22k including everything I have for the car.
Serious inquiry only, possibly trades for other racecars. Can add cash.
Videos:
Gorgeous car.
Not to go off topic, but do you have any info or write-up on that front splitter?
Gorgeous car.
Not detailed pictures sorry, its aluma-core (aluma-lite) bought from a local sign shop. Then made brackets that come down from the frame to support it as well as 4 adjustable rods, 2 in the front, and 2 inside right infront of the tires. I can get more detailed pictures for you?
Gorgeous car.
if you dont mind that would be great!! thanks!
