quick35th Posted September 4, 2012 Posted September 4, 2012 $750- Selling my set of CCW classics 17x9.5 in 5x4.5 bolt pattern. Perfect for 94-04 mustangs or fox mustangs with the hub swap. These clear the big Brembo 4 piston calipers. Mounted on them are 275/40/17 Continental non DOT endurance racing tires with 70% life left. Wheels are in great shape and no bends. Very slight rash on 3 of the 4 wheels. I have two extra shells that go with these. $600- Brembo '00 Cobra R front brake kit used. Kit comes with calipers, brackets, pads and rotors, and braided lines. Calipers work flawlessly, just some paint chipping from caliper bodies. Bolt these on and go. $2500 obo- For sale is a low mileage rebuilt Ford 5.0 stroked to 306ci originally out of a '92 mustang GT. This engine produces 350HP at the crank, about 315-330 at the wheels on past dynos. Heads are Trick Flow Twisted Wedge heads, ford x303 cam, Trick Flow 1.6 roller rockers, comp cams promagnum push rods, crane double roller timing chain, MSD distributor, ford racing plug wires, ford racing valve covers, stock crank and rods balanced and blue printed, speed pro .30 over hyper pistons at stock compression ratio, edelbrock performer rpm intake manifold, mighty demon 650cfm carb and one inch carb spacer, 7 quart drag oil pan. Engine will be sold complete turn key from carb to oil pan. Headers do not go with it. The engine is still in the car, you can come hear it run before purchase. It does not smoke or rattle, it is a very strong running engine great to be swapped into another mustang or another car. Engine puts down 310-320hp to the ground. Call or text me 614-668-5507. I can text pictures of any of the above parts. Shane Quote
snakebit Posted September 7, 2012 Posted September 7, 2012 Interested in the Brembo's. I'll text you in the morning. John Quote
