oregon87 Posted September 11, 2012 Posted September 11, 2012 I've decided to sell my track car. I was building it to AI/AIX specs. It's not quite legal yet, but it wouldn't take much. The only reason I'm selling is I'm building a V8 RX7 and would love a Ducati. Here's a list of the goodies. Engine (not installed yet, but will be in a few weeks. Everything is brand new) Stock block Scat 347 stroker kit and forged rods Comp XE282HR cam Mahle forged pistons World Product Windor Sr. aluminum heads. (2.06/1.60) Milled and some minor port work done 36lb. injectors Edelbrock RPM II intake manifold BBK headers and non cat H-pipe with 3 chamber Flowmater mufflers MSD 6AL box Canton road race pan Megasquirt ECU Stock T-5 Suspension Front Converted to 5 lug with Cobra brakes MM Fox forward offest control arms MM K-member MM strut tower brace. MM steering shaft. MM coil overs with Koni SA MM bumpsteer kit MM front sway bar (including the relocation and reinforcement kits) MM steering rack aluminum, adjustable bushings. MM camber/caster plates Rear 5 Lug SN95 length axles with Cobra brakes MM subframe connectors MM panhard bar MM torque arm MM coilovers with Koni SA MM lower adjustable control arms TA aluminum diff cover (3.73 gears) MM aluminum rear shock mounts MM adjustable rear sway bar Interior Stipped and caged custom aluminum dash and switch panel Autometer gauges Body 2 year old paint Weiner dog front fascia Rear spoiler made by Blaine Fabrication (you won't see another Mustang with one of these) Custom made side skirts (made to resemble Agent 47) Lexan rear window. Saleen 18" black 5 star wheels $10,000 It's already a very capable car. I can't imagine how competitive it will be with the 347. Email be at [email protected] for pics. Quote
