2000 Mustang GT | Street, Track, AutoX | MN | $4k
Name: Jacob Van Norman
Phone: five oh seven 3 2 3 two one two one (best way to contact me is a text!)
If you're looking for a nice street car, this is not it. This beauty has 127k miles of rage on it.
I bought the car three years ago with a mind to part it out because it had an unresolved engine issue. Turned out it was just a bad spark plug and a really bad exhaust leak, so I ended up driving it. Now, I don't have the passion to either make it into something or part it out, so it's time to move on.
Parts list
Chassis
Autopower 4-point roll bar
MM full length subframe connectors
MM strut tower brace
Kenny Brown lower K-member brace
Evolution Motorsport radiator enclosure 'V' brace
Front suspension
MM forward offset control arms with Delrin bushings
MM caster-camber plates
MM coilovers on Bilstein struts
Rear suspension
MM lower control arms with spring perch
MM torque arm
MM weld-in PH bar
H&R Super Race springs
KYB AGX adjustable shocks
Steering
MM steering shaft
MM aluminum rack bushings
Steeda bumpsteer kit
Brakes
Cobra all around
Braided lines
Power
Steeda underdrive pulley
Accufab intake plenum/throttle body
Magnaflow catted X-pipe
Magnaflow cat-back
Custom tune
Drivetrain
Torsen diff
3.73 gears
Aesthetic
2001+ smoked headlights
Mach I grille delete
BULLITT shifter
Rear wing removed (I think I have it somewhere)
Stubby antenna
Wheels
5Zigen FN01R-C, 17x10
The bad
* The chassis is tweaked - we can arrange a time to talk and I'll try to explain what I mean. Front jacking points are collapsed. Maybe the chassis will survive longterm, maybe not, but I think a full cage would be a good idea
* Number 7 cylinder eats a small amount of coolant during Minnesota winter
* Both rear wheel arches have met my roommates' cars on occasion, and there is a spot of rust that is through the body
* Parking brake needs to be reset and cables connected
* Clutch is still the original, so I'm including a spare. It will chirp the tires in second, so it doesn't seem to be slipping, but engagement is at the top of the pedal
* No seat buckles - only way to strap in is the harnesses
* CDs play only out of right side speakers
* Needs an alignment
The good
* I've put 15k street miles on this car in the last year and it's never left me stranded
* Gets 23mpg if you drive it like a granny
* Handles pretty nice
* Just replaced rear calipers
* A/C works
* I'm the 2nd owner, and I can try to get any info you want from the original owner
Spares
Used King Cobra clutch
Carbotech brake pads
Bunch of springs for the coilovers
Front control arms with adjustable spring perch
Front KYB AGX struts
Various conventional springs
Pair of used 265 Dunlop street tires
Probably some other stuff
I would keep driving this thing if I could make the time to fix it up - would be a fun winter car, autoX, rallyX beater. Or turn it into an all-out track car. But I have too many other things going on and can't make it that kind of priority.
$4000
If anyone is interested in an autocross or track build, I do have some other parts that could be helpful:
* MM rear coilovers with various springs
* Steeda 5-link rear suspension
* 302 (needs a rebuild), motor mounts, wiring harness, and PCM
* Aluminum heads and go-fast stroker parts
  • 1 month later...
