mrivard Posted September 26, 2012 Posted September 26, 2012 2005 Mazda RX8 16,500 [email protected] Car is located in Kansas City, email if you would like more info/pics History · Originally purchased to be raced in SCCA T3 class, never street driven. · Reworked in 2009 to be raced in SCCA EP class, and later PTD/C/B depending on ballast. · NASA and SCCA logbook · Legal in SCCA EP, and NASA PT, possibly SCCA STU class with a few minor changes · 2150lbs without driver · Entered 2012 NASA championship in PTD with a best lap of 1:39.6 in warm up, the motor unfortunately lost power on lap 2 of the race. The only bad news is the engine runs but will require rebuilding or replacement. · 2012 NASA Championships PTD Race Video: · TTC/PTC/PTB lap records at MAM · 1:39.6 at MidOhio in PTD trim · 1:08.9 at Gateway Drive line · 2009 factory Mazda motor with AEM dry flow cold air intake · Dual Oil Cooler Setup · Electromotive engine management and ignition · Speedsource Eccentric shaft and Alternator pulleys · All stainless steel long-tube custom header with 12 degree 3-1 collector by SPD exhaust · 3” single exhaust exit behind rear axle · Tilton 5.5” dual plate clutch · Mazdatrix ultra light aluminum flywheel - under 5lbs · Mazda series-1 RX8 transmission with AFE short shifter Dash · AIM MXL Pista gauge with GPS Sensors installed for Oil temp, oil pressure, water temp, and Fuel pressure Suspension · Koni 2812 shocks Hypercoil 2.25” springs Speedsource tubular front anti roll bar (OEM front bar included) OEM rear bar Wheels · 2 sets Enkei RPF-1 17x8 +35 offset front, 17x8 +45 offset rear · 20mm hub centric wheel spacers on all 4 corners Brakes · Custom 2 piece aluminum hats with vented rotors · Carbotech brake pads XP16 front, XP12 rear. The fronts were new before the NASA championship · Stainless brake lines Engine Cooling · 3 inch core custom radiator by Four Seasons Fuel Delivery · ATL 12 gallon fuel cell with integrated high pressure pump and pickup. · The cell is installed in passenger seat area and was new in 2012. NASA and SCCA legal. Driver Safety · Custom roll cage by KC Raceware Kirkey intermediate road race seat with cover · FIA rated belts expire in 2016 · Safety Solutions right side net · Window net · On board fire suppression system · MOMO steering wheel with quick release hub · Lexan windows all around Other Details · fiberglass trunk lid · aerocatch hood latches · lithium battery · transponder hard wired Spares · Driver side front and rear door · Passenger side rear door Quote
ovrstr Posted September 26, 2012 Posted September 26, 2012 I had the opportunity to race this car at various regional events and Nationals. Its a solid, fantastic handling and braking chassis. You'd be hard-pressed to find a lighter RX8 - the extensive weight savings gives numerous ballast weight options. During Sunday warmup at Nationals this car in PTD trim turned the fastest time of the weekend competing against factory supported Honda and Mazda competition. Great car, great seller. Quote
foxfan50 Posted September 26, 2012 Posted September 26, 2012 Would you be interested in a trade for a beautiful new 1999 spec miata? Quote
mrivard Posted September 27, 2012 Author Posted September 27, 2012 Thanks for the offer, if I were looking for another car I would certainly consider it. Just need to not have a car for the time being. -Matt Quote
mrivard Posted October 3, 2012 Author Posted October 3, 2012 As raced in the 2012 championships. Pushing Domo Quote
ovrstr Posted October 18, 2012 Posted October 18, 2012 Here's a few videos on the car during qual/race sessions. No affiliation with sale - just wanted to provide some additional info: Quote
RockLobster Posted October 19, 2012 Posted October 19, 2012 Someone needs to grab this, put a 13B-REW in it and go dominate ST3. Quote
