smbstyle Posted September 26, 2012 Posted September 26, 2012 (edited) Well I've got the itch for something new, so I'm putting it up for sale. Looking to sell the car straight out or trade for a 1.8 NA or NB with all the creature comforts still, either stock or with track mods (rollbar, wheels/tires, suspension, etc.) Just need something I can drive around town. Depending on the car, may do an even trade (well modded, dd'able track car, or stock with cash on your end. $6,900 with everything below (may be willing to take a few things off to reduce the price) car is located in Lakeland, FL, and will be at all of the Chin Sebring events if you want to check it out in person. Car has a current 2012 SCCA Logbook 1990 chasis w/ 162k miles - clear/clean title in hand and is registered for the street still 1999 1.8L motor w/ 75k miles swapped by Treasure Coast Miata 1.8L clutch put in during the swap as well by Treasure Coast Miata ton of maintenance while motor was out (cam seals, hoses, belts, timing belt, water pump, plugs, wires) MSD Digital RPM Window switch to control VICS on 99 motor OEM 5 speed trans black hardtop 02 sport brake conversion - Carbotech XP10/8 pads front/rear SPAL twin electric fans, main fan is wired to a 195deg thermoswitch, the A/C fan is wired to a switch in the cabin CX Racing Radiator New OEM coolant overflow tanks P/S and A/C have been deleted Koni yellow shocks with Flyin Miata springs Racing Beat sway bar adjustable end-links 15x7 TR Motorsports C1M Wheels w/ new Nitto NT-01 205/50R15 tires cat delete pipe going to Magnaflow race-muffler with a down-turn after (exits right before rear diff) SP engineering tow hooks custom built 6 point roll cage (1.75 x .120 DOM tubing used - high quality stuff) w/ NASCAR door bars on both sides Miatacage steering wheel quick release MOMO D-cut 320mm suede steering wheel Sparco ProADV Halo seat on side mounts Schroth Profi-II ASM 6 point harness Mesh window net w/ Advanced Autosports window net mounts AMB Transponder Passenger side trans-tunnel mounted fire extinguisher trunk-mounted ballast system On/off switch mounted to passenger side of cage Spare rear bumper Car is raced in SCCA STL at this time. Brakes are bled after every track event or race along with an oil and filter change (Rotella T6 w/ OEM filter), and trans and diff fluids are changed after every other event or race (AMSOIL 75w90 for diff, AMSOIL MTL in trans). The car is dead reliable on track, no overheating issues or anything, car runs great. The paint is in fair condition; has a few nicks, dents, chips and scratches. Hardtop was recently repainted flat black to match the hood, but there are a few cracks in the paint on the hardtop due to a little flex from racing. Those were touched up with touch up paint, but up close you can still see it. Also some light scratches in the glass on the hardtop, but i'll work on getting those buffed out. The metal behind the rear finish panel isn't completely straight - looks like the previous owner got bumped on track. The rear finish panel is spray painted black. The paint is actually in decent shape everywhere else though. Oh, and the interior isnt professionally painted - I used a can of white rustoleum gloss paint and a foam roller, but it actually turned out pretty decent and has several coats on it. There's a slight oil weep from the crank seal area on the engine, but I don't have any drops on the ground, so It's not a concern for me at the moment. In-car video: Edited November 20, 2012 by Guest Quote
smbstyle Posted October 20, 2012 Author Posted October 20, 2012 (edited) Price drop - $7900 new pics: Edited November 20, 2012 by Guest Quote
anthonybrizz Posted November 13, 2012 Posted November 13, 2012 i live in hudson fl about an hour from tampa. looking to start racing. just not sure which series to run or what car. Interested in your miata call or text 330 221 3628 Quote
smbstyle Posted November 20, 2012 Author Posted November 20, 2012 i live in hudson fl about an hour from tampa. looking to start racing. just not sure which series to run or what car. Interested in your miata call or text 330 221 3628 sent you a text. Quote
philooo Posted November 22, 2012 Posted November 22, 2012 Hey can you send me a PM, I am interested, located in south florida. I see the car has a tag, is the car street legal" .. I mean aside of the roll cage. Quote
jimwis811 Posted December 6, 2012 Posted December 6, 2012 If car is available pls call or txt 661 six zero nine 9859. Thx, Jim Quote
smbstyle Posted December 19, 2012 Author Posted December 19, 2012 If car is available pls call or txt 661 six zero nine 9859. Thx, Jim car still available, sorry for the late response, havent been on the forums for a bit. Quote
jimwis811 Posted December 24, 2012 Posted December 24, 2012 Hi, been very busy with holidays. I will try and reach you later this week. Thanks, Jim Quote
