FS: 1993 Mitsubishi Eclipse GSX race car
It is turnkey ready and is PTC\PTB class legal.
NASA Logbooked for 2012.
The particulars are below:
All-wheel drive
'93 shell
6 bolt motor
2689 lbs without driver or fuel
193+ whp on 12 lbs boost
White interior and exterior...new paint in 2011
Currently raced on 93 octane pump gas
Oil changed and brakes bled between every race weekend
Remainder of fluids replaced between seasons
Complete race recaps, notes and dyno sheets available.
Engine:
Stock 2.0 liter DOHC motor with balance shafts removed. Was rebuilt at beginning of 2007 season. It has seen 10 race weekends.
Head is shaved
ARP head studs
16G turbo
Manual boost adjuster
Ported Exhaust manifold
3" downpipe
Custom open exhaust to rear
2G MAF
Apexi AFC controller (5 knob)
Aftermarket fuel injectors (size unknown)
Walbro 190 fuel pump
Magnecor 8.5 mm igintion wires
K&N air filter
Custom pipe between intercooler and throttle body with 1G BOV
Urethane motor/tranny mounts
relocated stainless turbo oil feed line
Earlier 1G oil cooler (fin-type)
10W-30W synthetic oil used
Drivetrain:
Stock 5 speed transaxle rebuilt at beginning of 2007 season
Archer Racing center diff
Short throw shift kit
ACT 2600 clutch
stainless cluth hydraulic line
Factory 3 bolt rear LSD
Red Line fluids used
Suspension:
'Muellerized' JIC dampers/coilovers with full race spring rates and camber plates
Offset poly bushings on front lower control arms
15/16" rear sway bar
Front strut bar (bolt-on)
Rear strut bar (weld-in)
Front camber -2.8
Rear camber -1.5
0 toe front and rear
Cross weighted at 50%
Momo steering wheel
Brakes:
Front calipers: Wilwood aluminum 4 pot
Front rotors: Wilwood 13" x 1.25"
Polymatrix H and B compounds front pads
Stock rear calipers with functioning hand brake
Porterfield rear brake pads
Adjustable rear brake bias
ABS removed
Brake master cylinder stiffening bracket
Stainless brake lines at corners
ATE Racing brake fluid used
Wheels/Tires:
4 Enkei RP03 Racing wheels 17x8.5 w/ 35 mm offset
4 used Toyo RA-1 235/40ZR17 (seen 4 weekends)
Miscellaneous:
Carbon fiber hood vent
Oil temp gauge
Volt meter
Boost gauge
Baffled gas tank with modified low fuel light
Interior gutted except for dash
HVAC functional
A/C removed
Race specific:
Autopower 6 point bolt-in rollcage (SCCA and NASA legal)
Sparco 6 point FIA belts (4 years left)
G-Force drivers window net (4 years left)
right side head restraint
Sparco 2000 race seat
Rear seat brace
2.5 fire bottle bolted to passenger floor
Wink mirror
Optima red top battery relocated to rear
Kill switch mounted in dash
Doors gutted and glass removed
hood relase cable removed; 2 hood pins installed
Hood gutted
Bumpers removed
Sunroof deleted via sheet metal and rivets
weld-in bung on downpipe for wide-band 02 sensor
intermediate driveshaft saftey wired
turbo safety wired
Spares:
complete rear including suspension, diff/driveshafts
K&N air filter
control arms
rear driveshaft
Hoses, belts, etc
2G MAF
Center diff
transaxle
Intake manifolds
fans
radiator
stock intercooler
spark plugs
etc...
pics available on request.
Asking $5,000 or B/O
Contact me at [email protected] if interested.
  • 3 weeks later...
