H4CRXSi Posted October 30, 2012 Share Posted October 30, 2012 Welcome Kevyn! Not to burst anyone's bubble (Sam and Rob)... All the cool kids run H2... Just saying!! No worries, the coolest kids will be in H4 in 2013, LOL! Quote Link to comment Share on other sites More sharing options...
speedengineer Posted October 30, 2012 Share Posted October 30, 2012 No worries, the coolest kids will be in H4 in 2013, LOL! Naw - you got it wrong!! You mean in PTE... That is unless you know of about 3 people who will commit to H1 next season... Quote Link to comment Share on other sites More sharing options...
H4CRXSi Posted October 30, 2012 Share Posted October 30, 2012 No worries, the coolest kids will be in H4 in 2013, LOL! Naw - you got it wrong!! You mean in PTE... That is unless you know of about 3 people who will commit to H1 next season... H4...PTE...same for me either way just on different tires. As far as H1, I'm at a loss on finding those 3 people. Regards, Sam Quote Link to comment Share on other sites More sharing options...
H4CRXSi Posted November 5, 2012 Share Posted November 5, 2012 Just heard from Bruce Barger over the weekend and he will be doing comp school at Mid-O in April and racing his EF Civic SI in H4 as well! That gets us to four (4) H4 cars in the GL region in April, and Kevyn will be joining us once his build is complete and he does comp school. I'm sure there are more out there to come out of the woodwork once they see there is competition again. So far we have: Sam Myers - CRX Si Jim Feniello - DC Integra Rob Demorest - DA Integra Bruce Barger - EF Civic Si Kevyn Kistner - EG Civic Si Looking forward to a great 2013 racing in H4! Regards, Sam Quote Link to comment Share on other sites More sharing options...
porkchops22 Posted November 6, 2012 Author Share Posted November 6, 2012 Buddy of mine is trying to sell off his 91 CRX and other miscellaneous parts to try and fund a H4 EG hatch build as well. Not sure of his time table but he will eventually be with us too. Quote Link to comment Share on other sites More sharing options...
porkchops22 Posted November 12, 2012 Author Share Posted November 12, 2012 Alright, finally have a usable block and crank to start with. Got that rolling at the machine shop today. Now to start budgeting for LSD and suspension. Quote Link to comment Share on other sites More sharing options...
porkchops22 Posted April 23, 2013 Author Share Posted April 23, 2013 It has been a while since I have posted an update so here goes. Finally got the engine prepped and ready to go. I am going to go through the valves this weekend and start putting everything back on it. Also, the car came back from the cage shop yesterday but i still need to add two more bars. There was some confusion on whether the X design was legal or not. Next steps for me: *Paint cage *fix body work on chassis and paint *install rear disc brake setup *degrease/clean engine bay *order 4.9 FD gear set *order race seat, harness, and nets *order wheels and tires *Order correct brake rotors *figure out suspension Basically I have a ways to go and a few more thousand to spend. Quote Link to comment Share on other sites More sharing options...
speedengineer Posted April 23, 2013 Share Posted April 23, 2013 I thought the cage rules changed this year, to allow a rear x-brace design? CCR section "15.6.11 Rear Braces" Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted April 23, 2013 Share Posted April 23, 2013 From 2013 HC Rules: 4.9 Roll Cage All cars shall have a NASA CCR-compliant roll cage. Additionally, a) Any number of additional mounting points may be used. b) Any number of additional tubes may be used, even for chassis stiffening. c) Any size mounting plate may be used, subject to material and minimum specifications in the NASA CCR. d) Two (2) forward cage braces per side (total of four (4)) may pass through the firewall and connect at no more than two (2) mounting points in the engine compartment (i.e. strut tower or frame). e) Tubes may be welded at any contact point. Additional material may be used to connect roll cage tubing to chassis of car. I.E. A pillar bar may have material welded to both itself and the A pillar of the car. Additional spot welding and/or welding seams on the chassis is permitted. f) If any part or combination of modification number 4.9.e above is utilized, an additional thirty (30) pound weight penalty will apply. g) All tubes that are added shall be inspected for safety reasons. Any tube deemed to be hazardous to the driver must be removed. From 2013 CC&R: 15.6.11 Rear Braces The main hoop should have two (2) braces extending to the rear. The braces shall be attached as near as possible to the top of the main hoop, and no more than six (6) inches below the top. The braces should not contain any bends*. There must be at least 30 degrees between the plane of the main hoop and the plane of the rear braces. The main hoop rear braces shall be installed to form no more than a one hundred five (105) degree angle or no less than a seventy-five (75) degree angle with the main hoop when viewed from the top. may consist of an “X” pattern design. The main hoop braces may be mounted at the rear shock mounts or suspension pickup points (providing that the braces remain in compliance with all other sections of the CCR). They may go through any rear bulkhead(s) provided the bulkhead(s) is sealed around the cage braces. *There may be certain exceptions allowed for cars that cannot possible meet this “no bend” requirement. One exception is listed [Ref:(15.6.11.A)]. Other exceptions may be made if all of the required bars meet the specifications for a vehicle in the next heavier weight classification and the alternative design is submitted to the NASA National Office for special allowance. The red portion was crossed out and the bold portion was added for 2013. Quote Link to comment Share on other sites More sharing options...
porkchops22 Posted November 13, 2013 Author Share Posted November 13, 2013 Been a while since I updated. This trying to build a car from scratch thing is taking a lot longer than anticipated. Apparently time and money aren't as easy to come by as it used to be. Here is the dash finally cut down to fit back in over the dash bar. Engine buttoned up and just about ready to go back in the car. Next up: Ordering my new final drive gear, clutch and flywheel this week and will begin tearing apart my trans. Thinking I may go ahead and replace the bearings and synchros while I am in there. I can tell you this, I am really getting antsy. I want to get out on track but I refuse to take any short cuts. Oh well, slow and steady wins the race....right? (yea right) Quote Link to comment Share on other sites More sharing options...
