1995 Mustang GT Price Drop
Posted (edited)
I have for sale a 1995 Mustang GT I was building as a HPDE car and eventually a AIX car but work doesn't allow the time needed so the car must go asking price is 13,000.00 obo please no low ballers not in any real hurry to sell listed below is a list of parts the car has and specs thanks for looking Nick.
Engine:
Stock Block Bored 30 Over
Canfield Aluminum Heads Stage 2 Ported (Fox Lake) 64cc Combustion Chambers
Trick Flow R Intake Manifold Upper & Lower Stage 2 Ported (Fox Lake)
Jesel Comp Series Rocker Arms 1.72 IN/ 1.72 EX
Cam Motion Custom Cam
Forged Probe Pistons
1006 Felpro O-Ring Head Gaskets
1/2 ARP Head Studs
ARP Main Studs
Eagle ESP Connecting Rods
Comp Cams Solid Roller Lifters
0 Balance Eagle Crankshaft
Canton Road Race Oil Pan & Windage Screen
Comp Cams Hi-Tech Pushrods
Melling Hi-Flow Oil Pump
ATI 0 Balance Dampner
1 inch Trickflow Intake Spacer
Accufab 70mm Throttle Body & EGR Spacer
HPM Drop Solid Engine Mounts
Ford Racing Tall Valve Covers
Vortec S-Trim Supercharger
Vortec Oil Inlet Filter Kit
Anderson Power Pipe & K&N Filter
PA Performance 130 Amp Alternator
Hi-Flow Water Pump
Moroso Breather Tank
Exhaust:
3inch Magnaflow Mufflers
Magnaflow True X Pipe
V-Band Clamps
Custom Long Tube Headers
Engine Management & Ignition:
Motec M4 ECU/ M4 Adv Tuning & Logging Options Enabled/M4 Lambda Enabled
Motec M4 Relay Pack
Motec M4 Engine Sensors
Ford Racing 9MM Plug Wires
Ford Racing Distributor Cap & Rotor/Accel Distributor Module
VDO Oil Pressure Sender
New Starter
Bosch 4 Wire Lambda Sensor
MSD 6A Ignition Box & MSD Blaster 2 Coil
Drivetrain:
G Force Dog Ring Transmission
G Force 28 Spline Upgraded Mainshaft
G Force Billet Cluster Support
G Force .90 Overdrive Gear Set
G Force Heavy Duty Case
G Force Upgraded Shift Forks
Polyurethane Trans Mount
Quarter Master 8.5 Extreme V Clutch & Flywheel
Quarter Master Hydraulic Release Bearing
Alloy Axles 28 Spline Heavy Duty Axles
Ford Racing Limited Slip
ARP 1/2 Wheel Studs
Ford Racing Heavy Duty Diff Cover
Ford Racing 3.27 Ring & Pinion
Suspension:
AJE Road Racing K-Member & Control Arms
Steeda Caster Camber Plates
Steeda Heavy Duty Frt Sway Bar Mounts
Maximum Motorsports Tubular Lower Control Arms
Maximum Motorsports Bump Steer Kit
Flaming River Manual Steering Rack
Kennybrown Adjustable Front Swaybar & Drop Links
Race Craft Drop Spindles
Griggs Racing Coilover Kit
Koni Double Adjustable Shocks
Brakes:
Hawk HP Plus Brake Pads (Front&Rear)
Stainless Steel Brake Lines
Rousch 4 Piston Alcon Calipers & 14inch Front Rotors
Baer 13.5inch Slotted & Drilled Rear Rotors
Area 51 3inch Brake Cooling
Wheels & Tires:
Saleen Replica Black Wheels
18x9.5 Front
18x10 Rear
Toyo RA1
245/40/18 Front
305/35/18 Rear
Fuel System:
Vortec Hi-Flow Fuel Rails
Semens Deka 83# Injectors
Bosch Hi-Flow Fuel Pumps
-6 Fuel Feed Lines
-6 Fuel Return Line
Fuel Safe Mustang Cobra ProCell 22gal.
Hi-Flow Fuel Tank Pickup
Paxton Boost Sensative Fuel Pressure Regulator
New Fuel Level Sender
Interior:
Autopower 6 Point Roll Cage
Driver Seat Recaro SPG
Passenger Seat Recaro Pole Position
Schroth 6 Point Harness
Momo Steering Wheel & Adapter
Florida 5.0 Air Bag Delete
AIM MXL Strada Dash
Optima Battery Located In Trunk
Cooling:
Fluidyne Aluminum Radiator
15inch Flexlite Electric Fans
Setrab Oil Cooler (-8 Lines)
Ford Racing Silicone Hoses
Transmission Cooler (Setrab Cooler,Tilton Pump,-8 Lines)
CSI Aluminum Catch Can
Parts Included But Not Installed:
Steeda 5-link Rear Suspension
Hypercoil 750# Front Springs
Aim Speed Sensor
Spare Belts For Blower & Alternator
Autometer Fuel Gauge
Ford Racing 3.73 Ring & Pinion
Passenger Door Bar
Currently Car Has A Dent On The Roof, And The Driveshaft Needs To Be Rebuilt And Balanced Has A Vibration At Hi speed http://s1034.beta.photobucket.com/user/ford252002/library/mustang%20pics Pics of car
The car dyno at 616.57 HP and 494.08 Torque at the wheels we had a problem holding the car down it kept smoking the tires so the number should be higher then that.
Contact Info: Nick Avila
Phone (630)400-1163
Email: [email protected]
If you have any questions please don't hesitate to contact me thanks Nick
  • 4 months later...
Price drop 11,000 may consider parting the car out if there is enough interest thanks Nick
