Illbebetter
Unsure of classing 1990 CSP Miata
Illbebetter
I have a 1990 Miata I run in CSP. I can understand the points classing system exxcept for an engine swap. I am using a 1999 1.8l engine. base class for a 1990 is NXF** while a 1999 is NXE. If I class the car as NXF** I get 23 mod points not counting a penelty for the engine swap moving me to NXE. If I class the car as NXE I end up with 19 mod points(the difference is the lower tire width I am running) and I stay in NXE. What's the proper way to class this?
Share this post
Link to post
getfast
The proper way to class it is to do as it says in the rules. Email to get a new base class issued because of the engine swap, then add points from there.
Share this post
Link to post
trigger
do you have a dyno and corner weights for your car? My CSP miata with a 01 VVT engine landed in TTD*(+7). so my guess is you would be in TTD+/- a *.
Share this post
Link to post
