neukin Posted December 3, 2012 Posted December 3, 2012 $1450 brand new not used, someone stuck me with it so I need to get rid of as I have no use for it. Comes with 1 year warranty from Precision Turbo in Indiana Including a free 4" coupler and two stainless tbolts for your intake fab T3 hotside .63 and a 4" inlet antisurge S cover with 2.5" outlet. Has oil restrictor installed already.. just run normal -3an oil feed and then a -10an drain to oil pan. Specs of their site: PTE's PT5858 Turbocharger features the following: • Exclusive CEA® (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging • Higher efficiency and faster transient response for maximum power and performance • 58mm inducer compressor wheel • Compressor cover - "Ported S" compressor cover 4.0" inlet/2.5" outlet • 58mm, 76 trim turbine wheel - T3 .63 A/R with 4 bolt (2.5") discharge • Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA) <---- THIS is awesome because we dont have to run coolent lines to the turbo anymore SAVE more $$$ Quote
