Drftwizard Posted December 4, 2012 Posted December 4, 2012 I am selling my 1993 BMW E36 racecar with an LS1 engine and Tex Racing T101 dogbox. Car is very fast, makes 412whp, has a current NASA logbook and NASA annual tech inspection. The car only weighs ~2550lbs without driver with the magesium dogbox and all aluminum V8. The reason I am selling the car is I don't need two racecars, my other racecar is SPEC E30 #29. I am interested in all trades but I am really looking for another E46 M3 or possibly a newer diesel tow vehicle. Modification Highlights: E36 M3 Brakes Stainless Lines Relocated ABS Pump Mercedes S Class brake booster Tex Racing T101 4 speed dogbox, hardened input/output shaft, billet main bearing support. Long Shifter Shifter out of Mark Martins Go Daddy cup car 3:15 E36 M3 LSD Ground Control/Koni Competition Coilover Kit with custom valved shocks, 550lb/650lb springs New Lower Control Arms up Front Fixed forged Control Arm Bushings 17x8.5 Kosei K1's Vorschlag Mounts Vorschlag Long Tube Headers Vorschlag Competition Steering Shaft 4in Exhaust Comp Chromoly Pushrods Comp Dual Valve Springs Katech Rod Bolts 25% UD ATI Damper Katech belt tensioner LS6 Intake LS6 oil pump VA SPEED Custom Grind Comp Cam ~612lift Wizard Fab custom harness tuned on HP Tuner 415whp, 390tq Performance Touring custom trap door oil pan baffle Kirk Cage with a couple additional bars, NASCAR door bars, and Butteryfly door bars on passengers side Nitto NT01R 255/50 rubber ARC switch panel with relay box Driveshaft shop steel 3in driveshaft, good for 650hp Rear subframe reinforcement kit Rear Swaybar reinforcements RTAB reinforcement kit Full NASA spec fire suppression system, does not include bottle MOMO CUP GTR seat Wink Mirror Full Size wide angle drivers side mirror M&R window net Longacre Main Power Cut Off Really too much to list, must see in person. You couldn't build the car for twice what i'm asking. I have all receipts, total amount invested is obscene. You won't find another E36 like this anywhere. Video Walkaround Video Pics: Without cage PRICE: $20500 Quote
mdwilcox Posted December 5, 2012 Posted December 5, 2012 Where are you located? Also I sent pm with my contact info. Quote
Drftwizard Posted December 6, 2012 Author Posted December 6, 2012 Where are you located? Also I sent pm with my contact info. located in VA Beach, VA Quote
