bmw e36 ex world challenge $8000
ex world challenge speedtechnik car
was going to be a gts-2 car.
m52 2.8 : broke a retainer & bent a valve so head needs to be pulled - video camera in spark plug hole didnt show any piston damage. bottom end is on fresh rebuild new wiseco pistons,rings,bearings. also had rotating assembly balanced, arp head studs. running alpha-n tuning with a dta p8 pro stand alone. vanos locked. stock 325 cam,m50 intake, no MAF or idle valve - 204lb/197whp - with low compression pistons, was going turbo but then changed mind and shaved head to make up some compression. seam welded chassis, lexan windows at rear
lightweight flywheel/bimmer world clutchmasters segmented disc
supersprint exhaust headers (ebay version),custom catless - very very loud
extensive rollcage - id have to go check but i think it was 12 points
complete ground control suspension- looks like everything they offer for e36;
advance design double adjustable - custom valved - think its 800 fr/850 rear
ground control rear height adjusters
ground control camber plates
ground control rear adjustable lower control arm - spherical
ground control rtabs and front control arm lollipop -sphericals
front/rear adjustable sway bars, adjustable endlinks with sphericals
carbon 3D rear spoiler
kaaz lsd with 4.1 with welded on diff bolt reinforcer (puts bolt in double shear)
diy fiberglass splitter/undertray
extensive spairs - pallets of suspension pieces, half shafts, block, heads,hood,etc
(6) konigs 17x8
(2) 17x8 - might be konigs
wilwood front calipers with hawk 14s, 325 mm stoptech floating rotors (little use on rotors)
adjustable brake bias
rear stock calipers with hawk 12 pads
oil cooler
i believe i have some m3 cams around
bad; head, panel work (car was rolled before i got it, got sideways in gravel trap, rolled onto roof at low speed - small dents on roof), gas tank needs a new rubber seal behind driver, 2nd gear grinds but with 4.1 rear you dont use it, dta pro harness works (never had any problems) but was on list to redo to a 'race quality' harness
$8000 PLUS includes mychron gold display (h20 temp,rpm,oil temp,shift lights) and dl1 track mapper
going a different route with a mazda
spares list
lots of lifters/valves/springs/retainers/cam trays
m52 head with cams/lifters/springs/ - checking on cams if m3s
m52 head
m52 head ported but cracked
nib headbolt set
2.5 crank
2.5 connecting rod set of 6
used piston set (6) -should be 2.8
m52 block - not sure of bore but would need a rehone
rear subframe
(6) upper rear wishbones
(2) trailing arms with bearings/brakes/rusted rotors
front oil cover
(4) front control arms with spindles
(3) half shafts
alternator
nib valve cover gasket set
various connecting rods
some new oem pistons not sure of bore - prob 2.8 - think it was just 5 pistons
nib front hub/bearing
new front turn signal - clear
hood
another m52 block - bore 2.8 with crank
doors easily come off/on
