M3 S52 Motor For Sale
S52 Motor For Sale
VIN: WBSCD9324WEE07815
S52 from a 1998 M3 4 dr sedan automatic with 99k miles. Carfax shows only 2 owners before car was purchased as a donor in 2011. Compression and leak down tests performed by Rogue Engineering.
Engine Leak Down Test (12/11/12)
Cylinders #1 - #6 <5%
Engine Compression Test (12/11/12)
Cyl #1: 192 psi
Cyl #2: 190 psi
Cyl #3: 195 psi
Cyl #4: 192 psi
Cyl #5: 200 psi
Cyl #6: 200 psi
Additional parts:
S54 dual oil pump and pan
Euro Oil Cooler Kit/ oil filter housing
24lb injectors
803 MAF
VAC Tuned DME
New water pump and thermostat housing
S50 Manifold conversion
Engine was installed in my 1996 328 and used at 4 DE events and ran flawless. Oil pressure and water temps are in check.
Motor is very clean and does not leak any oil. All internals are stock.
Reason for selling is I am moving to an S54 so I can win all my DE’s!
I can send a video of the engine running to show oil pressure and water temps at idle as well as in car video showing vitals during a drive.
Price: $3000 plus shipping
Located in Northern NJ
Please PM with questions.
S52 Motor For Sale
Cyl #1: 192 psi
Cyl #2: 190 psi
Cyl #3: 195 psi
Cyl #4: 192 psi
Cyl #5: 200 psi
Cyl #6: 200 psi
Additional parts:
24lb injectors
803 MAF
VAC Tuned DME
Go*amnit, where were you 3 weeks ago?
  • 2 weeks later...
