Spartacus913 Posted December 12, 2012 Share Posted December 12, 2012 S52 Motor For Sale VIN: WBSCD9324WEE07815 S52 from a 1998 M3 4 dr sedan automatic with 99k miles. Carfax shows only 2 owners before car was purchased as a donor in 2011. Compression and leak down tests performed by Rogue Engineering. Engine Leak Down Test (12/11/12) Cylinders #1 - #6 <5% Engine Compression Test (12/11/12) Cyl #1: 192 psi Cyl #2: 190 psi Cyl #3: 195 psi Cyl #4: 192 psi Cyl #5: 200 psi Cyl #6: 200 psi Additional parts: S54 dual oil pump and pan Euro Oil Cooler Kit/ oil filter housing 24lb injectors 803 MAF VAC Tuned DME New water pump and thermostat housing S50 Manifold conversion Engine was installed in my 1996 328 and used at 4 DE events and ran flawless. Oil pressure and water temps are in check. Motor is very clean and does not leak any oil. All internals are stock. Reason for selling is I am moving to an S54 so I can win all my DE’s! I can send a video of the engine running to show oil pressure and water temps at idle as well as in car video showing vitals during a drive. Price: $3000 plus shipping Located in Northern NJ Please PM with questions. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 17, 2012 Share Posted December 17, 2012 Reason for selling is I am moving to an S54 so I can win all my DE’s! Very good reason! GLWS Quote Link to comment Share on other sites More sharing options...
Spartacus913 Posted December 22, 2012 Author Share Posted December 22, 2012 Reason for selling is I am moving to an S54 so I can win all my DE’s! Very good reason! GLWS Thanks! Come on GTS drivers...someone must need a solid replacement motor! Quote Link to comment Share on other sites More sharing options...
