toomchpwr Posted December 14, 2012 Share Posted December 14, 2012 I am thinking there will be a lot of guys jumping between TT3 and TT2 depending on car counts. I am guessing tunes will change to maximize allowable HP between the classes. Stinks to rely on honor system. I'm thinking specifically of last NARRA event at the Glen with GT3 car c5 z06 with aero (8.75 lbs/hp) ran 1:58 or something. I think the racers that have multiple tunes should make it known to competitors and TT director of this fact before each day in racers/TT meeting. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 14, 2012 Share Posted December 14, 2012 last year's dyno form: http://www.nasaproracing.com/rules/sanctioned/nasa_time_trial/ttdynoform.pdf 4th line I expect 2013's form to be very similar Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted December 14, 2012 Share Posted December 14, 2012 now the LSx world can flip a switch on the fly to, just like the turbo guys with the turn signal boost stalks I can tell you exactly why the "big cube" detuned motors are the thing in ST2 (and ST3) and it has nothing to do with the max torque, torque curve, or the above mentioned switch on the fly either. Quote Link to comment Share on other sites More sharing options...
heavychevy Posted December 14, 2012 Share Posted December 14, 2012 Data is getting cheap now, you can get a unit for $400 which in the grand scheme of this sport isn't much. I think it should be required for lap records, contingencies and wins. Dyno sheets should be ok for car counts, maybe points but it's too easy to cheat nowadays and a few people lacking the integrity not to take advantage of the system. Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted December 14, 2012 Share Posted December 14, 2012 Data is getting cheap now, you can get a unit for $400 which in the grand scheme of this sport isn't much. I think it should be required for lap records, contingencies and wins While I agree, cars (even similar cars) that pull the same dyno numbers on a dynojet in a 1:1 gear, can get from A to B in a WOT straight line pull in dramatically different time frames for a lot of reasons, some legal, some "legal" Quote Link to comment Share on other sites More sharing options...
z06tracker Posted December 14, 2012 Share Posted December 14, 2012 Pm me the answer....lol.... now the LSx world can flip a switch on the fly to, just like the turbo guys with the turn signal boost stalks I can tell you exactly why the "big cube" detuned motors are the thing in ST2 (and ST3) and it has nothing to do with the max torque, torque curve, or the above mentioned switch on the fly either. Quote Link to comment Share on other sites More sharing options...
Varkwso Posted December 14, 2012 Share Posted December 14, 2012 with engine controls on the new Ford and Chevy motors the detune is pretty easy and the "power switch" will also be easy. For example it is technically feasible to have more power on 1-3 and 5-6 and show a 4th gear pull showing the class limit. It will be a compliance issue but luckily competitors know when someone has 40 hp more out of corners. Proving it will be harder. I saw the effects of a stroker TTS car in December. Damn it pulls out of the corners with its torque. Quote Link to comment Share on other sites More sharing options...
brkntrxn Posted December 15, 2012 Share Posted December 15, 2012 But a Honda almost won the championships several years ago. Quote Link to comment Share on other sites More sharing options...
heavychevy Posted December 15, 2012 Share Posted December 15, 2012 Data is getting cheap now, you can get a unit for $400 which in the grand scheme of this sport isn't much. I think it should be required for lap records, contingencies and wins While I agree, cars (even similar cars) that pull the same dyno numbers on a dynojet in a 1:1 gear, can get from A to B in a WOT straight line pull in dramatically different time frames for a lot of reasons, some legal, some "legal" Thats fine. Just make them explain why at least. I know there are the clutches and aero tricks and maybe some stuff I dont know about yet. Cheating wont be eliminated, we there will be a stronger deterrent. Data will show hp application thoughout the lap. Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted December 15, 2012 Share Posted December 15, 2012 I saw the effects of a stroker TTS car in December. Damn it pulls out of the corners with its torque. Thing is, it shouldn't though, assuming you are running an M6 (or even better an GM motorsports or ZR1 box), you should never be below 5k, ever (when I say you, I mean in general, not "you"). It's all equal at 5250, so assuming @ 375 hp limit, any 5.7L motor is more than capable of making 375 ft/lbs in that rpm range and above (and would likely even need to be detuned to even do that) and any bigger engine would for sure be severely detuned at that rpm point. So they must follow the same torque curve (it must fall off) as rpm increases to hold the hp at a steady level. So two C5's are exiting a corner in 3rd gear, at 5400 rpm. Both weigh the same and thus have the same max hp allowed. One has a 427 and pulls the 346, yet both use the same gearing, and both must to follow the same torque curve from 5400 rpm on. Since the 346 motor is MORE than capable of making all the torque it needs from 5200+ to make it's hp goal, how is the bigger detuned motor an advantage? Your earlier post points to the answer. Quote Link to comment Share on other sites More sharing options...
Varkwso Posted December 15, 2012 Share Posted December 15, 2012 I saw the effects of a stroker TTS car in December. Damn it pulls out of the corners with its torque. Thing is, it shouldn't though, assuming you are running an M6 (or even better an GM motorsports or ZR1 box), you should never be below 5k, ever (when I say you, I mean in general, not "you"). It's all equal at 5250, so assuming @ 375 hp limit, any 5.7L motor is more than capable of making 375 ft/lbs in that rpm range and above (and would likely even need to be detuned to even do that) and any bigger engine would for sure be severely detuned at that rpm point. So they must follow the same torque curve (it must fall off) as rpm increases to hold the hp at a steady level. So two C5's are exiting a corner in 3rd gear, at 5400 rpm. Both weigh the same and thus have the same max hp allowed. One has a 427 and pulls the 346, yet both use the same gearing, and both must to follow the same torque curve from 5400 rpm on. Since the 346 motor is MORE than capable of making all the torque it needs from 5200+ to make it's hp goal, how is the bigger detuned motor an advantage? Your earlier post points to the answer. I know which one was quicker out of T7... Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted December 15, 2012 Share Posted December 15, 2012 I saw the effects of a stroker TTS car in December. Damn it pulls out of the corners with its torque. Thing is, it shouldn't though, assuming you are running an M6 (or even better an GM motorsports or ZR1 box), you should never be below 5k, ever (when I say you, I mean in general, not "you"). It's all equal at 5250, so assuming @ 375 hp limit, any 5.7L motor is more than capable of making 375 ft/lbs in that rpm range and above (and would likely even need to be detuned to even do that) and any bigger engine would for sure be severely detuned at that rpm point. So they must follow the same torque curve (it must fall off) as rpm increases to hold the hp at a steady level. So two C5's are exiting a corner in 3rd gear, at 5400 rpm. Both weigh the same and thus have the same max hp allowed. One has a 427 and pulls the 346, yet both use the same gearing, and both must to follow the same torque curve from 5400 rpm on. Since the 346 motor is MORE than capable of making all the torque it needs from 5200+ to make it's hp goal, how is the bigger detuned motor an advantage? Your earlier post points to the answer. I know which one was quicker out of T7... oh I believe you Quote Link to comment Share on other sites More sharing options...
gkmccready Posted December 15, 2012 Share Posted December 15, 2012 Thing is, it shouldn't though, assuming you are running an M6 (or even better an GM motorsports or ZR1 box), you should never be below 5k, ever (when I say you, I mean in general, not "you"). It's all equal at 5250, so assuming @ 375 hp limit, any 5.7L motor is more than capable of making 375 ft/lbs in that rpm range and above (and would likely even need to be detuned to even do that) and any bigger engine would for sure be severely detuned at that rpm point. So they must follow the same torque curve (it must fall off) as rpm increases to hold the hp at a steady level. You're assuming somebody hasn't swapped in a taller rear gear and runs a lower redline/revlimiter... (as I look at my 6.6L turbodiesel...) Quote Link to comment Share on other sites More sharing options...
Kubs Posted December 15, 2012 Share Posted December 15, 2012 I saw the effects of a stroker TTS car in December. Damn it pulls out of the corners with its torque. Thing is, it shouldn't though, assuming you are running an M6 (or even better an GM motorsports or ZR1 box), you should never be below 5k, ever (when I say you, I mean in general, not "you"). It's all equal at 5250, so assuming @ 375 hp limit, any 5.7L motor is more than capable of making 375 ft/lbs in that rpm range and above (and would likely even need to be detuned to even do that) and any bigger engine would for sure be severely detuned at that rpm point. So they must follow the same torque curve (it must fall off) as rpm increases to hold the hp at a steady level. So two C5's are exiting a corner in 3rd gear, at 5400 rpm. Both weigh the same and thus have the same max hp allowed. One has a 427 and pulls the 346, yet both use the same gearing, and both must to follow the same torque curve from 5400 rpm on. Since the 346 motor is MORE than capable of making all the torque it needs from 5200+ to make it's hp goal, how is the bigger detuned motor an advantage? Your earlier post points to the answer. The rate at which the torque falls off after 5250 will vary based on engine size. I know which method you are talking about to limit HP, but I dont think the 346 and 427 can be considered "equal" above 5200 RPM. Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted December 15, 2012 Share Posted December 15, 2012 The rate at which the torque falls off after 5250 will vary based on engine size. I know which method you are talking about to limit HP, but I dont think the 346 and 427 can be considered "equal" above 5200 RPM. Absolutely they have to fall off the same, the rate at which torque falls off has nothing to do with engine size. hp is equated from rpm, and torque. in order to "hold" it at a certain hp as the rpm ranges increase, it must drop in torque (and if you had a 375 hp flat line, it would have to drop in torque exactly the same, for any engine, of any size). Quote Link to comment Share on other sites More sharing options...
Varkwso Posted December 15, 2012 Share Posted December 15, 2012 While hp and torque are equal at 5250 the area under the curve does not always look the same above and below that point. Quote Link to comment Share on other sites More sharing options...
sperkins Posted December 15, 2012 Share Posted December 15, 2012 The only way to police it will be to limit cubic inches. Period..end of story. But wait, you can't do that. It would be impossible. So obviously that means that there is no way to police it. So that means that the hp/wt rule is essentially useless, which means 'why am I doing this again?' Quote Link to comment Share on other sites More sharing options...
Varkwso Posted December 15, 2012 Share Posted December 15, 2012 The only way to police it will be to limit cubic inches. Period..end of story. But wait, you can't do that. It would be impossible. So obviously that means that there is no way to police it. So that means that the hp/wt rule is essentially useless, which means 'why am I doing this again?' It is impossible to cheat the laws of physics. With good data systems and listening to what people say the systems will be ferreted out. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 17, 2012 Share Posted December 17, 2012 But a Honda almost won the championships several years ago. So much win...and sarcasm lol. Quote Link to comment Share on other sites More sharing options...
jrgordonsenior Posted December 18, 2012 Share Posted December 18, 2012 Thanks for the fun read guys. And here I was looking forward to all the T1 Vettes coming to play with me in ST2/TT2 next year. Jeez.... Quote Link to comment Share on other sites More sharing options...
Bnjmn Posted December 18, 2012 Share Posted December 18, 2012 Wouldn't a GPS tracker pick this up? The data used for that, as I understand it, is taken at nowhere near 4th gear speeds. Quote Link to comment Share on other sites More sharing options...
boomn29 Posted December 18, 2012 Share Posted December 18, 2012 last year's dyno form:http://www.nasaproracing.com/rules/sanctioned/nasa_time_trial/ttdynoform.pdf 4th line I expect 2013's form to be very similar ^^ This. I've been filling that section out and sometimes attaching another sheet of paper for YEARS to explain my multiple tunes. And more recently, we've required dyno sheets for all tunes. I've had to track down an official before to make sure he knows which tune I was running if I switched classes from Sat-Sun before so everything was updated BEFORE I hit the track in the morning. Wouldn't a GPS tracker pick this up? The data used for that, as I understand it, is taken at nowhere near 4th gear speeds. That's exactly what I was thinking. It logs from the moment it's turned on in the grid until tech takes it off. Quote Link to comment Share on other sites More sharing options...
sperkins Posted December 18, 2012 Share Posted December 18, 2012 Wouldn't a GPS tracker pick this up? The data used for that, as I understand it, is taken at nowhere near 4th gear speeds. I have no idea, but there would be a lot of variables to consider. For example (in our corvette world), a MN6 gearbox 2nd gear to red line and 3rd gear straight away pull would look different than an M12. Then throw in the ZR1 box and /or different rear end gear ratio and you'd be trying to decipher the data for hours. The whole point in swapping gears and trans boxes is to get from point A to point B quicker. Quote Link to comment Share on other sites More sharing options...
jason Posted December 19, 2012 Share Posted December 19, 2012 But a Honda almost won the championships several years ago. Can't argue with that. Quote Link to comment Share on other sites More sharing options...
Varkwso Posted December 19, 2012 Share Posted December 19, 2012 Wouldn't a GPS tracker pick this up? The data used for that, as I understand it, is taken at nowhere near 4th gear speeds. I have no idea, but there would be a lot of variables to consider. For example (in our corvette world), a MN6 gearbox 2nd gear to red line and 3rd gear straight away pull would look different than an M12. Then throw in the ZR1 box and /or different rear end gear ratio and you'd be trying to decipher the data for hours. The whole point in swapping gears and trans boxes is to get from point A to point B quicker. You are overthinking the physics of the problem... Quote Link to comment Share on other sites More sharing options...
