hondamaint Posted December 18, 2012 Share Posted December 18, 2012 I read the rules and maybe I missed something. I wanted to know if we can run an automatic transmission in HC. Anyone know? Quote Link to comment Share on other sites More sharing options...
Members Marcel D. Posted December 18, 2012 Members Share Posted December 18, 2012 Why would you want to do that?. Just curious about it. Quote Link to comment Share on other sites More sharing options...
hondamaint Posted December 18, 2012 Author Share Posted December 18, 2012 It's a long story but we want to race a vehicle that only has an auto transmission. It already has an SCCA log book for TT but they will not allow the auto in club racing. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 18, 2012 Share Posted December 18, 2012 8.4 a) The flywheel may be replaced with others of unrestricted origin, provided it is the same diameter as stock and would accommodate a stock clutch and pressure plate. (See item b) as well.) b) The clutch and pressure plate may be replaced with others of unrestricted origin so long as the pressure plate would bolt to a unmodified OEM flywheel. c) Limited slip differentials are unrestricted but must fit into an unmodified OEM housing. d) Final drive ratio is unrestricted. All other gearing must remain OEM in part and gearing. No mention of A/T or A/T components. 10.2 d) Any OEM transmission that bolts directly to the block may be used. Adaptor plates are not permitted. Internal gear ratios must remain OEM for that series of transmission expect for the final drive ratio. Bold portion would lead me to believe A/T would be ok. Quote Link to comment Share on other sites More sharing options...
AZELISE Posted December 18, 2012 Share Posted December 18, 2012 What Simon is saying is that he interpreted that it is not legal in H5 through H3 but is legal in H2. He didn't bother to check H1. And neither did I. Quote Link to comment Share on other sites More sharing options...
hondamaint Posted December 18, 2012 Author Share Posted December 18, 2012 Ok thanks. We are making plans for next year. I read the rules and wanted to just make sure I was not missing something. Thanks. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 18, 2012 Share Posted December 18, 2012 What Simon is saying is that he interpreted that it is not legal in H5 through H3 but is legal in H2. He didn't bother to check H1. And neither did I. 8.4 is for all classes (H1-H5)...and with the fact that everything mentioned was in regards to a manual...I don't know what that means...I'm just putting three dots between thoughts for dramatic effect... Quote Link to comment Share on other sites More sharing options...
