FS: 93 Honda Civic Hatch w. Built N/A ITR Swap (Toronto, On)
For sale without Rims and tires (car will come with steelies)
interested parties please email me at:
[email protected]
Motor
B18C5 Integra Type R w/ Transmission
Gord Bush Prepped, Built by Pro Spec
Never driven in the winter
Maintenance is as follows:
Oil Changes every 5000 KM
with:
Shell Rotella 5W40 Motor Oil
w/ S2K oil Filter
Spark Plugs Changed yearly since rebuild in 2010 with:
NGK BKR7E-11
Motor Details:
Ferrea Valves
Crower Dual Valve Springs
1997 OEM Type R cams
Skunk2 Adjustable cam gears
Ported and Polished
Head re-surfaced
RS machines Pistons
Competition Stage 2 Clutch w/ lightweight flywheel
Hytech replica header
Baffled Oil Pan
JDM Type R valve cover
USDM Type R valve cover (Cam Gears Cut, vented for catch can as well)
Hasport B-Series Mounts
Suspension
Koni Yellow Sport Shocks
Ground Control Coilovers
Ground Control Front top Hats
Skunk2 Pro Series Front Camber kit
Blox Rear toe and Camber kit
Hardrace rear trailing arm bushings
Skunk2 Rear LCA
ASR Rear subframe brace
JDM ITR sway bars front and back
Spoon Authentic rear tower strut bar
Megan Front tower strut bar
Brakes
Integra Type R front calipers
1" Integra Type R master cylinder
Si rear disc conversion
Stainless steel brake lines w/ ATE Superblue Fluid
Exhaust
Mandrel bent 2.5in straight pipe w/Vibrant 3in Flat black muffler
Interior:
Del Sol Front Seats (driver/Passenger)
Megan C-pillar bar
Auto Power Roll cage
Misc:
USDM Headlights w/ Stock Corners
Red/Clear Taillights
Pricing works as follows:
For the whole car - $5450 negotiable.
Or if there are certain things about the car that you do not want, I will remove what you dont want and will negotiate the price and adjust accordingly
just email me
If Interested parties only want the ITR Engine Swap price is as follows:
Engine swap will include the ECU, shift linkages and necessary parts to swap.
In other words COMPLETE Swap
$3675 Negotiable/Flexiable/Throw a fair offer.
[email protected]
