2012 BMWCR IP Nat'l Champ car/NASA GTS3 e36 M3 for sale
Posted (edited)
2012 National Championship winning car BMWCR IP, multiple GTS3 class winner for sale.
This car needs nothing. Just flush the antifreeze out, change the oil, and drive.
Chassis
BMW e36-96 M3/93 325 (easy to explain)
Suspension
Moton Street-Sport "single adjustable," 2 seasons old. Solid rear mounts
GC adjustable front camber plates and adjustable rear swaybar
Hotchkis adjustable front swaybar
VAC adjustable rear camber arms
Quick ratio Z3 steering box
Engine/Drivetrain
S52 with factory overbore bottom end, one season, OBD I conversion with M50 head
Sunbelt race cams with upgraded valve springs
BW Race intake/BW BBTB
New 24lb injectors last year
AA Race headers, full 3" race exhaust
E46 oil pan with dual oil pickups
E46 oil filter housing with E46 under-radiator oil cooler
BW/ C&R aluminum race radiator, one season
Stock gearbox with BW solid race shifter
Latest generation BW strapless clutch
3.73 custom rear-end with diffs online ramps, finned diff cover
Solid mounts throughout
Brakes
Wilwood front BBK with PFC DD rotors
Stock rear setup
Full front brake ducting with brake backing plates
Exterior/Aero
BW CF rear wing
BW front dive planes
Brand new windshield
Interior/Safety
Kirk cage, 1.5" X .120 steel, SCCA/NASA/BMWCR certified
Cobra Evolution 2 seat (2006), braced
Schroth Hans harness, DOM 2011
Window net DOM 2011, R side net DOM 2012
Spa mechanical fire system, two pulls
Traqmate "Complete" data/video integration system with heads-up touchscreen display, remote camera start, remote sensor input/alarms
Oil temp/pressure, water temp gauges
Remote tach with shift light
Momo race wheel with quick release
Longacre ignition switch with key-delete
IOPort camera mount
(water bottle holder not included)
Car weighs about 2750 empty, dry. BW restrictor plate set included for NASA if desired ( I ballasted up)
Included in this price:
One set Kosei 17X8.5 with heat-cycled only R6's
One set SSR 17X9 and 3 sets Hoosier R6's, 245/40/17, various conditions
Coolshirt cooling system with controller
FAST helmet blower system(on/off only)
  • 2 weeks later...
Posted (edited)
price updated
  • 3 weeks later...
  • 1 month later...
Shakedown completed this past weekend.
No issues, car is ready to race. Just add gas.
Fresh NASA-certified dyno sheet available on request
  • 1 month later...
Price adjustment...
22k takes everything
Fresh HG just in
