shiza40 Posted January 17, 2013 Share Posted January 17, 2013 The time has come for me to sell my beloved BMW race car. It has served me well as a street car, HPDE toy, and for the last two seasons, a race-winning car in NASA’s GTS-2 class. It is fully prepped and ready to go. Buy it today, and put it on track tomorrow as a competitive racer or a safe and reliable HPDE car. Asking $18,000. For more info, send me a PM or email me at: shiza40 at y a h o o dot com The car is located in Cary, NC Drivetrain: 3.0L S50 OBD-I M3 Engine (stock for reliability) Top end rebuild in 2011 by Cylinder Head Specialties 226hp/217tq unrestricted Plate restricted to 204hp/205tq for GTS-2 Getrag 5-speed Jim Blanton built 3.23 differential Solid engine and trans mounts Cold air intake with K&N filter Active Autowerks Supersprint cat-back exhaust Bimmerworld all-aluminum radiator 88-degree thermostat Aluminum thermostat housing Suspension: M3 Suspension components Ground Control Track/Race Coilover Kit Koni Top Adjustable Shocks Eibach Springs (550F, 600R) Camber Plates Treehouse Racing FCA Bushings/Brackets Racing Dynamics adjustable sway bars (front and rear) Ground Control adjustable sway bar endlinks (front) Powerflex RLCA Bushings Front shock tower reinforcement kit (welded) Front subframe reinforcement kit (welded) Rear subframe reinforced (welded) Bimmerworld rear sway bar reinforcement kit Bimmerworld rear trailing arm reinforcement kit BMW front shock tower reinforcement plates Z3 steering rack (2.7 turns lock-to-lock) Kosei K1 wheels: 17x8.5, ET40, 16.8lbs (2 sets) Bimmerworld spacers Tires: BFG R1, Nitto NT01, BFG KDW Brakes: M3 brake components PFC pads Brass caliper guides Safety/Interior: Six point custom fully welded cage built by Competition Cages High-density foam roll bar padding Sparco ProADV driver’s seat Corbeau Forza passenger’s seat Momo Mod78 320mm steering wheel OMP steering wheel adapter NRG steering wheel quick release G-Force 5-point harnesses (driver and passenger) Custom alumalite driver’s floorboard Welded dead pedal AMB Transponder (hardwired) Bimmerworld race tow hooks (red) Longacre kill switch TeamTech center net Scroth window net VAG fire extinguisher mount Misc.: All fluids Mobil-1, Redline, or Motul Constant oil changes and fluid flushes Custom vinyl by Extreme Vinyl and Black Forest Industries APR GTC-200 wing with custom uprights Custom splitter with integrated undertray Empty weight: 2,774 lbs Quote Link to comment Share on other sites More sharing options...
shiza40 Posted February 2, 2013 Author Share Posted February 2, 2013 Sold! Quote Link to comment Share on other sites More sharing options...
