CMC 98 Mustang GT 4.6: Sold
Posted (edited)
1998 Mustang GT
Ready to race
Built in 2008
Current log book.
Passed tech June 2012
4.6L SOHC
PI Heads
Fresh paint and body work.
Super clean inside and out.
Torsen with 3:73 gears
MM Panhard Bar
Tokico D-Spec Single Adj F/R shocks
linear rate rear springs (2 sets)
linear rate front springs (2 sets)
MM Strut Tower Brace
MM full length sub frames
MM rear lower CA’s
Steeda upper diff mounts
Argent Labs front lower spherical
MM rack solid non-offset bushings
MM bump steer kit
MM camber plates
Aluminum Radiator
PS cooler
Spec Stage clutch
MM clutch quadrant & adjuster
TR3650 5 speed
Ford Racing Alum drive shaft
Cobra PBR calipers in front w/12" rotors
Brake ducts
Bias adjuster
Fire Suppression System
Schroth 8 point F1 style Harness
Two sets of MB Competition 16x8’s.
One set of shaved with a little life left.
The following only have five events on them:Alternator, water pump, PS pump, brake booster and fuel pump
The following only have three events on them: Torsen, 3:73 gears, PHB, Trans rebuild and clutch.
Car finished 1st at 2010 Nationals but was DQ’d for a minor technicality related to the strut tower brace which has since been addressed. I purchased in Dec 2010, ran 5 events and invested in the paint, bodywork, Torsen, PHB, trans rebuild, new clutch, etc.
Plenty of references available.
Includes the following:
Used (backup) hubs, rotors, pads
Spare springs: 900/325
4.6 bottom end (piston, crank, cam, rods, Canton oil pan) – build / backup plan
Tremec T-45 trans (needs rebuilt).
Set of RA1 rains (full tread) that have only one event on them (yes, already mounted on wheels).
Brand new set of Hawk DTC 60’(rear) & 70’s (front) - still in plastic.
Sparco seat (passenger seat mount already in car).
3:55 rear gears (used in only one event).
PM me if interested and I can provide more information as well as some more pictures. Here are few for now. On the dyno last year. Don't let the "AI" confuse you. I ran an event where I would have been the only CMC car so I stuck these on and ran with AI to help with car count for Toyo Bucks.
  • 4 weeks later...
Spares now included and price dropped.
In interested. Please send email with more pictures new price and your phone number.
[email protected]
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
