BillB Posted January 31, 2013 Posted January 31, 2013 I've decided to sell my 2003.5 Mazdaspeed Protege. I've owned the car since it was new. It started out as my daily driver and has been a dedicated track car since 2008. The car is currently set up for TTD. In the 5 national championships this car has competed it has 4 championships and 1 second place. The car set the TTD track record for MidOhio at the 2012 championships (1:38.997) and has multiple regional track records. Car weighs 2350 without driver or ballast. The modifications on the car include: 6 point Roll Cage 2 sets of Hoosier A6 Tires (225/45/15) mounted on 15x8 Rota Slipstream Wheels (both sets of tires were new for 2012 Championships) KSport Coilovers with 500 lb/in Front Springs; 850 lb/in Rear Springs AWR Adjustable 21 mm Rear Swaybar AWR Front Endlinks AWR Motormounts AWR Oil Pan Injen Intake Self-Fabricated airbox with headlight inlet Hardpipes Front Mount Intercooler Corksport 2.4” S and J pipes 2.5” Catless Midpipe Self-Fabricated Midpipe-back Exhaust Split Second Air Fuel Controller Carbotech XP-12 front brake pads Carbotech AX-6 Rear Brake Pads Steel Braded Brake Lines Summit Brake Proportioning Valve RCI 6-point Harness Ultrashield Pro Road Race Seart Mesh Window Net Self-Fabricated Seat Mount Self-Fabricated Front Bumper and Tow Hook Spring loaded Rear Tow Hook Fidanza Aluminum Flywheel Exedy Stage 1 Clutch Carbon Fiber Hood with heat extraction holes Autopower Boost, Oil Pressure and Oil Temp gauges ARP Wheel Studs Lexan Windshield Lexan Rear Side Windows Self-Fabricated Airdam and Undertray Odyssey Battery, Relocated to Passenger Side Floor SPA Fire Suppression System Also comes with an aluminum rear spoiler and a front splitter and air dam. Documentation of the work on the car through the years and many pictures and videos on my website at http://www.breesmotorsports.com With extra spoiler and splitter The bad: It needs a 3-post electrical cut-off switch installed, needs a new driver side axle, two of the bars on the roll cage were found to not have 360 degree weld so they will have to be touched up, and it has high mileage on the engine which is original to the car (about 110,000 miles). Asking $5000 in its current condition. Quote
green45 Posted August 23, 2013 Posted August 23, 2013 I just want to out 3 small photo's which I need help identifying which is best one and i am also want to buy this model . Quote
