onefstm Posted February 2, 2013 Posted February 2, 2013 (edited) This race car was built by Treehouse racing in Tennessee and originally campaigned in BMW CCA and PBOC. At the time it has a Euro S50B32. I bought the car last year and completed a S54 swap in the car. last spring It makes 292 RWHP (345hp flywheel)on a Dynojet (2 weeks ago) with a stock tune. More power is available with an Epic Tune. Here is a summary of the parts: 1995 e36 m3 chassis with a full 1.20x0.95 DOM cage, NASA/BMWCCA legal, painted body color. Nascar bars drivers and passenger side 2003 e46 m3 engine with new water pump, thermostat, VAC rod bearings and ARP rod bolts, pulleys, intake, welded oil pump nut. Runs on factory ECU with stock tune and 8000rpm redline Blanton Performance Gearing 3.64:1 differential with diff cooler Ground Control full coilovers with Koni SPGC shocks Racing Dynamics swaybars X-brace Ground control camber plates and rear toe adjustment arms Powerflex black subframe / trailing arm bushings JB racing flywheel with 6 puck clutch, sachs pressure plate e36 5 speed transmission 3.5" exhaust with headers, borla muffler and resonator e36 m3 ltw euro rotors, bronze bushings in calipers, SS lines, hawk ht14 pads F/R bimmerworld dual fuel pump aluminum radiator electric fan Momo steering wheel with quick disconnect hub 18" BBS RK wheels Sparco EVO passenger seat MA Shaw LTW rear wing Vorshlag motor and Trans mounts Current belts (10/2010) 2012 Recaro SPG XL drivers seat ( I also have another 03 Evo that could be swapped in place) Approximate weight 2750 Great paint and super straight body Car runs outstanding and fires up instantly. I ran two days in the car last year at Atlanta Motorsports Park and Barber. I have video from another car for the AMP day and also have video from the dyno. My plan was the run this car in the NASA GTS series. However, the closest track (Road Atlanta) is 5 hours away and I just do not have the time with my business and young kids. Trades ACCEPTED: Porsche 911, Cayman, GTR - I am willing to add cash for the right car. Looking for street cars or mildly modded track cars. $29,500 - located in TN - Here is an ad with pictures: http://www.racingjunk.com/NASA-GTS-Challenge/181713852/95-BMW-M3-Race-Track-car-with-s54-swap.html Edited February 3, 2013 by Guest Quote
onefstm Posted February 3, 2013 Author Posted February 3, 2013 Here is the ad on racingjunk: http://www.racingjunk.com/NASA-GTS-Challenge/181713852/95-BMW-M3-Race-Track-car-with-s54-swap.html $29,500 - Tennessee 615-3oo-3988 or jeremy dot r dot sweeney at gmail dot com. Thanks Quote
