Race Winning 99 Spec Miata--SOLD
Trimless1
This car was built in 2009 and placed 1st in the Houston Autorama car show. I purchased the car in 2010 and have developed this SM into a front running national car with several podium finishes. The car has very limited use in the last 2 years and has only 15 race weekends since build. The car is ready to race as is and needs nothing, all maintenance is up to date and NASA / SCCA log books are included. The car has never been wrecked other than tire marks and a slight dent the the front fender. Scales and aligns perfectly with 3+ degrees of camber available all 4 corners. I've done all the work to make the car very light and rolling resistance is minimal !
Details as follows:
Gilfus Racing Pro engine and transmission (8 weekends) Leak down numbers are excellent at 2 to 3%.
Miata Cage with nascar bars on both doors
Torsen Diff
Fat Cat bump stop kit
Adjustable Fuel Pressure regulator trunk mounted.
Timing Wheel with 14 degree advance
Ultrashield head containment seat w/ G Force Pro cam lock belts
Aluminum Radiator
Fire System
Momo steering wheel with quick release
SD Exhaust
Fuel Test Port
ARP long wheel studs
Adjustable end links
Stewart rebuilt shocks
Braided clutch line
Advanced Autosport oil relocation kit
Team Dynamics Pro Race 2 wheels
Side windows removable for storage
SS Brake Lines
Gauges: Oil, Water, Air/Fuel ratio and tach. Warning lights for oil and water.
Recent Items replaced:
New Windshield
New Battery
New Act Clutch and Pressure Plate, slave cylinder
New OEM Front Hubs
Rear hub bearings replaced
New Front and Rear brake calipers
$18,000 located near Houston, TX
Send me a PM for photos.
