chucky_d Posted February 11, 2013 Share Posted February 11, 2013 Looking to register for the watkins glen HPDE1 event this april. I was wondering if anyone knows what the policy on two drivers using the same car? Also- We will only be attending 1 day of HPDE Quote Link to comment Share on other sites More sharing options...
Bnjmn Posted February 11, 2013 Share Posted February 11, 2013 No problems with sharing a car (as long as the car is up to it), but you will need to split the time if you are both in the same DE session. Quote Link to comment Share on other sites More sharing options...
chucky_d Posted February 12, 2013 Author Share Posted February 12, 2013 No problems with sharing a car (as long as the car is up to it), but you will need to split the time if you are both in the same DE session. Awesome. Do you know if both drivers have to pay the entry feeor is it one fee per car? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted February 12, 2013 Share Posted February 12, 2013 Your region registration will know for sure Quote Link to comment Share on other sites More sharing options...
08Bullitt0572 Posted February 17, 2013 Share Posted February 17, 2013 Keep a close eye on the brakes and tires, especially if the sessions are back-to-back. I have seen shared cars end up with boiled brake fluid and worn pads and it ended their fun early. Quote Link to comment Share on other sites More sharing options...
chucky_d Posted February 17, 2013 Author Share Posted February 17, 2013 Sent a couple emails, still waiting for a response. I emailed the regional director, no response and I recently emailed the generic "info" email, still waiting. If everything goes as planned I should be running fresh dot5 fluid, and upgraded brakes, everything I've read pretty much says the brakes are the #1 priority for these events. Quote Link to comment Share on other sites More sharing options...
Calif_Kid Posted February 17, 2013 Share Posted February 17, 2013 Sent a couple emails, still waiting for a response. I emailed the regional director, no response and I recently emailed the generic "info" email, still waiting. If everything goes as planned I should be running fresh dot5 fluid, and upgraded brakes, everything I've read pretty much says the brakes are the #1 priority for these events. Chunky - is that Dot5 Silicone based fluid, or maybe 5.1 fluid? I've heard in the past, that the Silicone based Dot 5 fluid doesn't work well on the track with some info in http://www.stoptech.com/technical-support/technical-white-papers/brake-fluid. I'll list some other threads on brake fluid below. Personally, I use Motul RBF600. - Jim viewtopic.php?f=1&t=57374&hilit=dot+5+brake+fluid viewtopic.php?f=37&t=45202&hilit=dot+5+brake+fluid viewtopic.php?f=37&t=29191&hilit=dot+5+brake+fluid viewtopic.php?f=1&t=14976&hilit=dot+5+brake+fluid&start=20 Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted February 18, 2013 Share Posted February 18, 2013 shop by boiling points (dry and wet), not DOT number Quote Link to comment Share on other sites More sharing options...
