hydeciel Posted February 14, 2013 Posted February 14, 2013 Hello, Two questions, I think I have everything else figured out. I have a 2003 Nissan 350z Base Model. I have some considerable suspension modifications. I need clarification. I've searched for a while for this answer, but haven't found anything remotely helpful. The two questions are centered around the following: E9. Replace or modify control arms (other than plates, shims, slots, or eccentric bolts/bushings for simple camber/caster adjustment only) or RWD/AWD rear trailing arms (may have spherical/metallic joint for the connection to the spindle/knuckle) +4 Question one: What are the rear trailing arms for the 350z? I have megan rear camber arms which replaces/deletes the spring buckets, rear radius arms, and adjustable rear lower arms. Are these rear trailing arms? Question two: If they are, I currently have megan adjustable camber/control arms installed in the front of my car as well. Does this mean I add a total of 8 points, or is it saying if I have atleast one I total 4 points? My current set of mods without considering the above arms are Coilovers +3 (no piggy back or external res., also caused me to delete the spring buckets), springs+2, LSD +3, and, swaybars +2. Totaling 10 points. Thank you, Mike Quote
TurboShortBus Posted February 16, 2013 Posted February 16, 2013 Question one:What are the rear trailing arms for the 350z? I have megan rear camber arms which replaces/deletes the spring buckets, rear radius arms, and adjustable rear lower arms. Are these rear trailing arms? Yes. +4 minimum. Throw in another +3 per E23 if you have spherical/metal bearings of any kind. When in doubt, e-mail National Director Greg Greenbaum directly. Mark Quote
Varkwso Posted February 17, 2013 Posted February 17, 2013 Mark nailed it.. Another useful tip, establish a good line of credit. The addiction has no known cure. Quote
