944 Parts
Cleaning out the garage this winter and off-loading excess 944 parts. I've got a full list (not sure how to post) which I can provide. Feel free to contact me at christiancook43(at)yahoo(dot)com if you need something.
Pricing is 50% of new, 75% of a dismanteler or 95% of ebay.
Below is the list of P/N and discriptions:
Engine
Multiple "1988, 944, 2.5L engine, complete
-High compressoin,'88 euro pistons
-Milledge cam
-Gellner Engineering 951 head w/ 951 valve springs
-951 oil filter housing
-Late turbo, deep oil pan
-includes waterpump & cam / balance shaft pulleys
-Built by Steinels Autowerks
-178hp (151hp & 150ft*lbs torque at wheels)
-48 hours, last run 2008
-Cylinders oiled for storage and turned periodically"
944.104.303.8R "Complete 944, 2.5L head
-Refreshed in '08 by Gellners Eng, Assy. by Steinels Autowerks
-Port, polish, competition valve grind, matched valves to ports
-951 valves & springs
-28 hours on head; not part of blown motor"
Multiple "1988, 944, 2.5L engine block, pistons & crank
-Scored #2 cylinder"
944.101.201.6R Oil Pan, late turbo
944.103.111.2R "Connecting Rods, late 968, forged w/ reinforced bearing cap (17mm)
2 good (2 questionable, no cost)"
944.105.250.07 Camshaft housing
951.106.921X Waterpump, 944 turbo
944.375.123.03 Engine carrier, L
944.375.124.02 Engine carrier, R
944.101.042.02 Gear carrier, R (balance shaft)
944.107.014.11 Oil pump
944.110.095.03 M44.08/10 Throttle housing (throttle body)
944.110.358.04 Air box, j hose, no cracks (j-boot)
944.606.121.01 Mass air flow meter 8 valve non turbo
944.110.052.02 Intake manifold, 8 valve non turbo
944.106.125.06 Coolant expansion tank
951.106.031.50 Radiator, turbo
944.504.167.01 Protective plate, plastic engine cover, non turbo
Bremtek Lightweight flywheel
Electrical
944.618.121.05 ECU - Bosch Motronic - 1988
944.603.109.00 Alternator
944.603.134.01 Alternator bracket
951.604.101.00 Starter
928.631.070.00 3rd brake light
477941379B Electric motor for pop-up headlight
944.624.021.03 Electric fan (radiator - includes shroud 944.106.141.02 )
477955113B Windscreen wiper motor
Brakes
944.351.429.00 Floating caliper, front, L
944.351.430.00 Floating caliper, front, R
944.352.429.00 Floating caliper, rear, L
944.352.430.00 Floating caliper, rear, R
944.355.011.00 Brake master cylinder
944.355.023.00 Brake booster
Transmission / Dirvetrain
944.116.043.06 Clutch housing / cover (check casting number)
944.421.012.02 Torque Tube
TBD Pressure Plate, Steel - Sachs 3032 055 099
TBD Pressure Plate, Aluminum - Sachs 3082 015 399
Multiple Gearshift lever w/ knob, boot & base
944.424.019.00 Gear shift rod
Suspension, Front
944.341.103.06 Control arm cross member /LL (Engine cradle)
944.347.011.24 Steering Rack, 944, power steering
944.347.033.01 Tie-Rod, 924 / 944 early
944.347.333.01 Tie rod end power steering
Rear Suspention
951.331.021.01 Rear trailing arm, right
951.331.022.01 Rear trailing arm, left
951.332.235.01 Rear wheel shaft, 2x
999.053.020.01 Rear wheel bearing, 2x
951.331.067.00 Wheel Hub, 2x
944.332.038.09 Drive shaft, right
944.332.038.10 Drive shaft, left
944.331.901.00 CV Joint, 4x
Custom Torsion bars, 13mm, solid (for use w/ coil over rear springs)
944.331.045.02 Rear-axle cross-tube
Body
477.807.109 Bumper, Front, 924S
477.807.155A Rubber moulding, front impact pad, Left
477.807.156A Rubber moulding, front impact pad /Right
477.807.301A Bumper, Rear
477.807.158 Rubber moulding /R
477.807.157 Rubber moulding /L
944.505.017.03 Impact absorber, bumper shock
937.512.555.00 Rear spoiler, 944, center section w/ L&R sides
477.827.555 Rear Spoiler, 924S, center section w/ L&R sides
944.219.888.09 0507 Driver side, 944 mirror assembly complete, alum frame, motor / glass
944.219.888.09 0505 Passenger side, 944 mirror assembly complete, alum frame, motor/ glass
477.898.027 Driver side, 924 mirror assembly complete, manual
477.898.028 Passenger side, 924 mirror assembly complete, manual
Inteior
944 641 015 02 Dashboard clock
477 959 530 Air-conditioning switch
944 641 117 02 Guage, Oil pressure
477 941 531 Switch, headlights
477 857 137 Cover light switch black; Bezel, headlight switch
477 959 623 Rear window heating switch
477 953 235 Emergency light switch; Switch, hazard
477 857 138 Cover switch rear window heating black /R; Bezel, defrost & hazard switch
477 862 185 Rear hatch release switch-satin black, w/ mouthing; Switch, rear hatch release
477.953.901 Turn signal switch, black
477.953.902 Wiper switch, black
944 617 150 Relay warning indicator oil level
944 641 030 01 Speedometer
944 641 310 02 Temp/fuel/pressure
477 857 123 1DB Glove box cover black /LL
477 857 283 AFP7 Instr.trim cover, black
477 953 515 B1DB Lining black, top
477 953 516 B1DB Lining black, bottom
321 905 851 Steering lock housing
477.957.807.B Drive shaft, speedometer cable
477 867 012 RKZ8 Door panel, passenger
Multiple Carpet set
Multiple Passenger seat, black, vinyl
Multiple Rear seat, lower, black, vinyl
Multiple Back seat, upper, black, vinyl
Wheels
911.361.032.28 Hub cap black, for fuchs / cookie wheel only (4 black, 4 red)
928.361.032.01 Hub cap silver metallic, phone dial or disc wheel
Race Parts
Elephant Racing Adjustable Bump Steer Kit for Porsche 944
Weltmeister Weltmeister lightweight "star" spacers (pair), 22mm
Momo Steering wheel w/ mounthing adapter, model V35
Eibach 700lbs
Eibach 950lbs
Fabcar Fabpin / ball joint for Fabcar a-arms
ATL Fuel cell
Recaro Recaro racing seat, SPG
MSD MSD Ingniton
MSDS MSDS header
Lindsey Racing Lindsey oil breather
Racer's Edge Lower torsion tube bushings
Racer's Edge Spring plate, Delrin inner
Racer's Edge Spring plate, Delrin outer
