Sign in to follow this
TowDawg
Thunder Roadster Set-Up Questions?
TowDawg
I finally bought a track car after looking at what it was costing me to track the Viper as much I was. After considering a lot of options, I ordered a TR, and talked a friend into ordering one as well. We picked them up from 600 racing a couple of weeks ago and have been going through them and familiar with everything, adding the electronics, getting them ready for coolsuit systems, etc.
Now we are ready to start with the corner weighting and suspension/alignment set-up. Can anyone give me a good baseline in terms of caster/camber/toe, panhard settings, cold tire pressure, etc? I know we'll have to run them and make adjustments depending on personal preference and driving style, but a good baseline would make it whole lot easier.
I know we can ask the guys running them at the track, but we would like to have them pretty well set-up when we get to the track, and I'm not sure how much we'll be running with NASA this year. We're planning on running HPDE's with a lot different groups at different tracks this year to get the feel for the cars and then run the TR series with NASA in 2014.
Share this post
Link to post
Darrel
Everyone runs a slightly different set up but start with about -3 degree's of camber, and about 2 to 3 of caster with the top leaning back, (old age I can't remeber if that's positive or neg.) about a 1/16 of an inch toe out and the panhard bar about 3" up on the frame, 18lbs cold in front and 16 lbs cold is rear. That should get you close. Keep in mind that if the rear is not stepping out you are not driving it hard enough.
We would be delighted for you guys to come jion us in the South SE. We have over 20 active roadster racing with 10 to 15 showing up at every race.
Share this post
Link to post
TowDawg
Thanks Darrel!
That at least gives us a base set-up to tweak from.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
