mwh911rs Posted February 25, 2013 Share Posted February 25, 2013 well, after qualifying and racing at VIR the other weekend, my inspection of the new RRs revealed 3 of 4 tires with a visible tread splice. Anyone else see this? granted I did spin in T10 during the race, but nothing too significant. I will post some pictures asap. one or two look pretty similar to what is shown in the Toyo advisory, the other isn't quite as distinct. Quote Link to comment Share on other sites More sharing options...
sean Posted February 26, 2013 Share Posted February 26, 2013 Mark, can you post some pictures of the damage? Between this and robs picture of a chorded tire on face book im getting nervous about these RR's. Quote Link to comment Share on other sites More sharing options...
whaden Posted February 26, 2013 Share Posted February 26, 2013 Mark...are your RR's mounted per the instructions per the advisory? Picts would be nice. Quote Link to comment Share on other sites More sharing options...
ffspecracer Posted February 26, 2013 Share Posted February 26, 2013 Toyo RR Tire Advisory Quote Link to comment Share on other sites More sharing options...
mwh911rs Posted February 26, 2013 Author Share Posted February 26, 2013 Mark, can you post some pictures of the damage? Between this and robs picture of a chorded tire on face book im getting nervous about these RR's. Rob was running RA1s Quote Link to comment Share on other sites More sharing options...
mwh911rs Posted February 26, 2013 Author Share Posted February 26, 2013 Mark...are your RR's mounted per the instructions per the advisory? Picts would be nice. yes i was. Keep in mind, he advisory doesn't say that it won't happen if you follow the directions, it specifies tire mounting and rotation recommendations to minimize the possibility of them appearing and making the condition worse. I did have a spin and that would put a tremendous amount of shear into the tire, so maybe that contributed to it. I will post pics later. they may or may not be bad, but the fact that I got them the first time out sux. I will rotate them per the instructions and run them in March. It is another thing to have to worry about. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted February 26, 2013 Share Posted February 26, 2013 seeing the splice is one thing. do they have a history of separating/failing? Quote Link to comment Share on other sites More sharing options...
arob Posted February 26, 2013 Share Posted February 26, 2013 Mark, can you post some pictures of the damage? Between this and robs picture of a chorded tire on face book im getting nervous about these RR's. Mark is correct, Sean. I was running hand-me-down RA1s that got a lot of use last season. I only used them on Friday for comp school, then pulled them for the rest of the weekend. I'm sticking with RA1s for now, as I'm still getting my feet wet with this whole racing business. Quote Link to comment Share on other sites More sharing options...
mwh911rs Posted February 26, 2013 Author Share Posted February 26, 2013 seeing the splice is one thing. do they have a history of separating/failing? they don't have a long history Pete....they are new. I am talking with Phil about it. It is not unexpected...I just don't like seeing it the first time out in 3 of 4 tires. If the tires aren't rotated properly, then Toyo indicates that there is the potential for the splice to open up (that is the subject of the advisory). it is probably not a problem, just an additional thing to keep track of. Quote Link to comment Share on other sites More sharing options...
Spartacus913 Posted February 26, 2013 Share Posted February 26, 2013 Does Toyo offer contingency to SPEC3 racers? Quote Link to comment Share on other sites More sharing options...
dbgeek Posted February 26, 2013 Share Posted February 26, 2013 seeing the splice is one thing. do they have a history of separating/failing? they don't have a long history Pete....they are new. That was my point. From another forum: I find this part funny... "The appearance of a visible tread splice is not a defect in the tire.", immediately followed by, "However, unless appropriate steps are taken, this condition may result in an open tread splice, which will require the tire to be immediately removed from service and replaced." So, it's not a defect, but it applies to this specific tire enough to issue a TSB about it, and oh by the way, it can ruin the tire. But it's not a defect! Very glad I don't have to deal with the Toyo monopoly these days. Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted February 26, 2013 Members Share Posted February 26, 2013 Mark's photos and sequence of events have been provided directly to the National office. I will advise on their response. Mark, your spin was fairly short lived as a large amount of your rotational movement was in the grass. Additionally, a simple spin should not cause a tire to begin separating. Someone else asked about contingency, yes Spec3 does receive Toyo contingency dollars. Quote Link to comment Share on other sites More sharing options...
mwh911rs Posted February 26, 2013 Author Share Posted February 26, 2013 Mark's photos and sequence of events have been provided directly to the National office. I will advise on their response. Mark, your spin was fairly short lived as a large amount of your rotational movement was in the grass. Additionally, a simple spin should not cause a tire to begin separating. Someone else asked about contingency, yes Spec3 does receive Toyo contingency dollars. Thanks for taking this up Jon. Well, the spin was pretty low-key, but as a "researcher" i am always throwing out all the ideas that come to mind...hahaha, it is my curse. Just so everyone knows, i was more just letting people know what I saw in my tires and to see if anyone else saw the minor splice indications. As Toyo states, this can happen and the advisory is there to keep it from becoming a problem. I had no intention of making it into a red flag...just an awareness. Quote Link to comment Share on other sites More sharing options...
whaden Posted February 26, 2013 Share Posted February 26, 2013 Just so everyone knows, i was more just letting people know what I saw in my tires and to see if anyone else saw the minor splice indications. As Toyo states, this can happen and the advisory is there to keep it from becoming a problem. I had no intention of making it into a red flag...just an awareness. yep...taken just as that, although I did actually envision you taking measurements...noting starting and ending pressures and noting which tire was on which corner....(track temps/wind sheer/angle of the sun/rotational mass...and so on) Which makes me think...of the four - which corner did not show the evidence of splice? Right front? Quote Link to comment Share on other sites More sharing options...
Scany Posted March 5, 2013 Share Posted March 5, 2013 not liking this. We should allow lower race weight for RA1s this season while these new RRs get "broken in". Would let us use up our tires as well. Quote Link to comment Share on other sites More sharing options...
dbgeek Posted March 5, 2013 Share Posted March 5, 2013 I just lost 13 pounds by dieting with the wifey There are quite a few items I could remove - wiring, heater core, blower. How much you wanna lose? Quote Link to comment Share on other sites More sharing options...
Members Jon M. Posted March 5, 2013 Members Share Posted March 5, 2013 Hopefully a more reasonable set of weather conditions in March will prove the RR's to be fully reliable. No doubt it is an issue we are all going to watch closely. Quote Link to comment Share on other sites More sharing options...
johnnylove Posted March 27, 2013 Share Posted March 27, 2013 Hopefully a more reasonable set of weather conditions in March will prove the RR's to be fully reliable. No doubt it is an issue we are all going to watch closely. so, what's the report? how'd they hold up? anyone else see issues? Quote Link to comment Share on other sites More sharing options...
mwh911rs Posted March 28, 2013 Author Share Posted March 28, 2013 Hopefully a more reasonable set of weather conditions in March will prove the RR's to be fully reliable. No doubt it is an issue we are all going to watch closely. so, what's the report? how'd they hold up? anyone else see issues? they seemed to do much better. I had Phil look at the tires after every session and they seem to be clearing up. took photos to send to Toyo. We we keep everyone posted. Quote Link to comment Share on other sites More sharing options...
matisrev16 Posted January 6, 2020 Share Posted January 6, 2020 On 2/26/2013 at 10:20 PM, Jon M. said: Mark's photos and sequence of events have been provided directly to the National office. I will advise on their response. Mark, your spin was fairly short lived as a large amount of your rotational movement was in the grass mutuelles TNS. Additionally, a simple spin should not cause a tire to begin separating. Someone else asked about contingency, yes Spec3 does receive Toyo contingency dollars. It may be the hub that was not tightened properly and that caused the tires to come off. Quote Link to comment Share on other sites More sharing options...
