mike2727 Posted February 25, 2013 Posted February 25, 2013 (edited) Putting my 1997 M3 Racecar / Trackcar with brand new LS2 stroker motor up for sale, circumstances prevent me from doing any track events in the coming years, so she has to go unfortunately This Car is complete and ready to be taken to the track Also selling my open trailer but only after the car is sold, or as a package deal with the car The Trailer is 25ft, double 7k axles, new winch, new tires, new wiring, new brakes and bearings Asking price for the trailer is US-$ 3,500.00 1997 E36 M3 Coupe – Race Car (+/- 2750lbs) with new LS2 build Stroker motor (485 whp/511wtq) Asking price: US-$ 46,000.00 OBO (over $ 90,000 invested) Location : Hollywood, FL 33021 Contact : [email protected] Video (walk-around) : http://www.streetfire.net/video/walk-around_2420155.htm Some pictures + Dyno : http://www.streetfire.net/photo/378jpg_2124855.htm Here are the specs:1997 E36 M3 Coupe – Race Car (+/- 2750lbs) Full 10-Point Roll Cage Reinforced Suspension points Custom E46 metal fender flares (welded) New wiring throughout the car Hardlines for Fuel and Brakes Lexan Rear and side windows Large adjustable front splitter 2 Functional Naca ducts Braille lightweight Battery (17lbs) SPA Fire System with 3 nozzles HID Headlights Driver window net Custom Dual Side Out exhaust Carbon Fiber Rear Wing Front and Rear Tow Hooks Cooling ducts from front bumper to Brakes, Starter and Alternator Big Sway Bar (front) – OEM rear Sway Bar Tilton adjustable Pedal Assembly (Brake + Clutch) Separate Master Cylinders for Front and Rear (no ABS) In Car Brake Bias Control (F/R) Custom Dash switch panel Custom Extended Steering Rack Sparco Quick Release Steering Wheel Custom Aluminum Floors (insulated) and Transmission tunnel Recaro Pole Position (FIA 2010) driver seat Schroth Profi-II 6 / 6 point Harness (FIA 2011) Passenger Blitz Race Seat Passenger Willans 6 point Harness Suspension: KONI SA Shocks Hypercoil Springs 600lbs (F) / 700lbs ® Ground Control Camber Plates Eibach Front Sway Bar – OEM Rear Sway Bar Turner Adjustable Rear Camber Arms Solid mounts Drive Train: New GM LS2 motor (only dyno and 1 DE at Homestead +/- 50 milesdriven) Fully build Stroker Wiseco Pistons Eagle forged Rods (H-Beam) Eagle forged Stroker Crank Custom grind Comps Cam Comps Cam pushrods Lunati double valve springs Clevite Bearings ARP bolts throughout Stage 8 locking nuts (headers) L92 Ported heads Cometic Head Gasket L76 Intake 90mm TB (DBW) GM ECU with GM Engine harness High Performance Starter CTS-V 150 Amp Alternator C5 Lingenfelter CAI K&N Air Filter Custom Headers (Nahrod) with Jet HotCeramic coating Custom CNC Motor and transmission mounts(Nahrod) Custom Drive shaft / steering rack (Nahrod) Dual In-Tank Fuel Pumps New SLP High Performance Oil Pump New PRW High Flow Water Pump Mishimoto Aluminum Radiator 3000 cfm Radiator Fan FBody Oil Pan with Improved Racing Baffle T56 6-Speed Transmission QuarterMaster Button lightweight Flexplate QuarterMaster Triple 7.25” Clutch, hydraulicwith remote bleeder / reservoir New Canton 3 Quart electronic Accusump (notyet installed) New Canton Remote Oil Filter New Oil Cooler with Fan 3.38 LSD Rear Differential with Rogue DiffCover Rear Diff Oil Cooler with Fan and pump Brakes (no ABS): New StopTech Race Kit (custom piston setup)4 piston 14” front New StopTech Race Kit (custom piston setup)4 piston 13” rear New CarboTech RP2 (front) / XP10 (rear)pads In Car Brake Bias Control (F/R) and in car fluidreservoirs 6 rims APEX ARC 8 – 18x10 with 295/30/18Hoosier R6 (light weight) 4 rims 18x8.5 spare for wets Video and Data Acquisition: TraqMate Classic Complete with Display TraqMate RPM input module ChaseCam PDR 100 ChaseCam SS1000 with 2 Bullet Camera’s (forDual Camera PiP recording) Bluetooth ODB-II Scanner for custom Gauges– needs a 7” Android Bluetooth (not included Tablet (+/- $ 200) + Torque Pro program ($ 6) Miscellaneous: In Car mounted Battery Tender In Car Rust Stop Device (to be used duringstorage) Spares: BMW 3.91 LSD Rear Differential 2 – New 255 lph In-Tank Fuel Pumps Spare Mishimoto Radiator Fan Miscellaneous Chasecam parts + extra (3rd)Bullet Camera GM Stock LS2 heads GM Stock LS2 Intake GM Stock LS2 Injectors Edited August 21, 2013 by Guest Quote
mike2727 Posted June 26, 2013 Author Posted June 26, 2013 PRICE DROP !!!!!!!!!!!!! NEW PRICE $ 40,000 Quote
