1991 Spec Miata for Sale
Posted (edited)
SOLD!
1991 Spec Miata Race Car for Sale – NASA/SCCA
I am selling a very clean 1991 Mazda Miata that can be raced in the NASA or SCCA Spec Miata series. It was also registered and inspected as a street car in North Carolina, so you can drive it to the track and drive it home! The car is in excellent condition (Southern car), and needs little to be race ready. Here are the specifics:
- 1.6L Engine
- 5 Speed Manual Transmission
- Manual steering rack
- Hard Top
- Full six point welded cage, fabricated by Krause & England in Raleigh, NC
- Mazdaspeed suspension kit (springs, dampers, stops, sway bars)
- Shift light
- Longacre mirror
- Tow hooks
- Window net
- Battery cutoff switch
- 2 sets of Kazera KZ-M 15x7 wheels (Street Tires on one set, Toyo Proxes RA-1 on the other)
- UltraShield Rally Sport seats (17" driver, 18" passenger)
- Adjustable sway bar links
- ART intake w/K&N cone filter
- DaLan Tow hitch (used to tow tires and toolbox to the track)
Over the past few years, the following has been done to the car:
- Timing belt (including water pump, front main seal, CAS and cam seals)
- Clutch (including rear main seal and front/rear transmission seals)
- Radiator (including cap and Upper and Lower hoses)
- Shift boots
- Spark Plug wires
- Clutch slave cylinder
- Front and Rear brake calipers, pads (Carbotech) and rotors as well
- Fuel Filter
- Battery
The car needs the following to be race ready:
- AMB transponder (for timing)
- Upgraded (1999) suspension hats, required for SCCA and NASA
- New driver harness (date expired)
- If it were going to tracked only, I would also remove the muffler and catalytic converter, and replace it with a straight pipe
I will try and post pics soon. The car is white in color, and ready for your decals. First $6300 FIRM takes it home. Located in Herndon, VA, near Washington, D.C.
[email protected]
