Yellow Snake Posted March 3, 2013 Posted March 3, 2013 98’ SVT MUSTANG COBRA $29,500.00 RACEJUNKAd #181748934 25,538 miles on streetable track car. Licensed and titled. All build documentation provided. 301.20 RWHP 294.58 RWTQ on Dynojet dyno 6/20/12. Over $58,000.00 and seven years invested. 2012 N.A.S.A. Central Division TTA Champion. ENGINE AND DRIVETRAIN 4.6 L Teskid Block Canton oiling system w/Fragoloa lines & fittings (Redline Oil) BBk62mm throttlebody Walbro 255 LPH fuel pump BBK adjustable fuel pressure regulator WMS cold air intake w/march intake tube Pro-M 87 mm MAF BBK LT ceramic coated headers w/stage 8 bolts BBK off road H pipe ceramic coated Flowmaster ceramic coated mufflers MSO DIS-4 w/MSD coils and thunder volt 10mm wires Braille light weight battery Custom crankcase breather system LFP/Fluiddyne aluminum radiator Meziere electric water pump SCT X3 Tuner Steeda billet clutch quadrant and firewall adjuster Innovators West underdrive crankshaft dampener Ford racing aluminum driveshaft HPM driveshaft safety hoop Torsen T-2R limited slip diff. 31 spline Moser 31 spline axles w/ARP studs Moser aluminum rearend cover Ford racing 3.73 and 4.30 gear sets Pro- 5.0 shifter Ford Racing A/C delete SUSPENSION AND CHASSIS ASP solid motor mounts ADDCO front sway bar w/Steeda aluminum mounts Flaming River solid steering shaft Kenny Borwn matrix subframe connectors Auto power custom cage 1.75” x .1.20” D.O.M. Complete maximum motorsports track package Koni double adjustable coilovers BRAKES Front Brembo 4 piston w/Hawk DTC 70 pads Rear stock w/Hawk DTC 60 pads Baer 2 piece rotors front & rear Spare Brembo front & stock rear rotors Russell S.S. brake lines front & rear Quantum Motorsports brake cooling ducts WHEELS AND TIRES 1 set 18X9.5 2000 Cobra R wheels w/275 Hoosier R6’s 1 set 18X9 & 18X10 GT wheels w/295 & 305 Toyo R888’s EXTERIOR AND INTERIOR Ford Racing 95’ Cobra R hood w/billet hood pins Cobra Monaco racing seats Simpson 5 point harnesses G-Force window net Momo steering wheel Longacre 14” convex mirror SRP racing pedals X2C rear seat delete G-Tech Pro data system Florida 5.0 gauge panel Autometer Phantom gauges RACEJUNKAd #181748934 Quote
