loren fancy Posted March 5, 2013 Posted March 5, 2013 Nice Honda Challenge car with 90%+ of the work done, in great condition. Runs great and handles very well, leaks nothing. I have 2 cars and really only have space and time for one. 97 Acura GSR NASA H2 Race Car NASA LOG BOOK 2013 YEARLY TECH Makes Weight with 220Lb Driver Location: Southern California $9500.00 Engine & Trans Stock B18c GSR with ARP Head Bolts Hondata 300 Tuned on Chassis Dyno Skunk Intake with Hondata gasket Type R Throttle Body B&M Fuel Pressure Reg and Gage Cold Air Intake 410cc RDX Injectors Hytech Try Y Header with Custom Exhaust 2 Qt Accusump with AN fittings Innovative Engine/Trans Mounts Mishimoto Radiator Catch Can 30 Row Oil Cooler with AN fittings GSR Trans MFactory 4.9 Final Drive MFactory Metal Plate LSD New 3rd/4th slider New Synchrotech Carbon Lined Synchros Excedy Clutch and Pressure Plate Light Weight Chromoly Fly Wheel Chassis 1997 Acura GSR Roll Cage with NASCAR Bars Carbon Hood Carbon Roof Splitter Brake Cooling Ducts Mugen Style Wing with interchangeable Gurney Wings Benen Tow Hooks front @ rear Russel Brakes Lines Suspension & Wheels Enkie RPF1 15 x 7.. 4ea Black 4ea Silver Progress 24MM adjustable rear sway bar Energy Suspension Bushings H & R Aluminum Coil Over Shocks H & R and Eibach Springs with Helper Springs ARP Wheel Studs Skunk Wheel nuts Billet Aluminum Wheel Spacers SPC Rear Toe Adjuster Skunk Rear Camber Adjuster Hardrace Front Upper Control Camber Kit with Hard Bushings Hawk Blue Pads Safety & Interior Roll Cage, Window Net, Padding Momo Steering Wheel with Quick Release Crow 5 point Belts Race Tech Seat XL Race Tech Side Net Quick Car Floor Mat Joes Shifter Boot Brake Bias Auto Meter Tach, Shift Light, Oil Pressure. Oil Temp, Water Temp Longacre Mirror Longacre Kill Switch, Ignition Switch Panel Fire Bottle Fire System Fast Cool System Tray Sparco Gas and Brake Pedal More Pictures on request. Loren Fancy 818-266-3843 [email protected] Quote
loren fancy Posted March 11, 2013 Author Posted March 11, 2013 HAD REQUESTS FOR MORE PICTURES fd5.jpg[/img] Quote
