Shawn T.
Track Records for the Mid South Region
Shawn T.
Please review and note any discrepancies...
Track: Memphis International Raceway (new records in bold)
Class Name Time Date
AI Jeremy Moen 1:13.475 11/9/2013
CMC Joshua Thomas 1:22.202 11/10/2012
GTS1 Victor Kelly 1:23.331 9/28/2013
GTS2 Rob Case 1:15.953 6/30/2013
GTS3 Werner Stark 1:12.169 11/9/2013
GTS4 Werner Stark 1:16.557 5/5/2012
HC1 Rob Oxford 1:17.717 6/30/2013
PTD Chris Viscovich 1:17.943 11/9/2013
PTE Trey Walker 1:23.019 3/2/2013
Spec E30 Chris Tuttell 1:18.719 11/9/2013
STR3 Dave Schram 1:15.915 11/9/2013
STR2 Dave Schram 1:18.006 11/19/2011
SU Joshua Thomas 1:11.653 11/10/2013
ST1 Brad White 1:13.802 11/10/2012
ST2 Dennis Mitchell 1:15.486 11/10/2012
Spec 944 Jeremy Pohlman 1:19.721 11/9/2013
Spec Z Clark Crawford 1:15.738 11/9/2013
TT1 Larry Bailey 1:09.208 6/30/2013
TTA Bret Butler 1:16.201 11/10/2012
TTB Wynn Suebhongsang 1:15.553 6/30/2013
TTC Rob Case 1:17.781 11/19/2011
TTD Randall Conn 1:23.418 11/10/2012
TTE Randall Conn 1:23.164 11/10/2012
TTF Bud Scott 1:31.516 7/10/2011
TTS Jim Davenport 1:17.042 5/6/2012
TTU Larry Bailey 1:14.663 3/3/2013
TTR Anton Dias Perera 1:17.068 11/10/2012
Will be adding the other tracks we have visited as well but wanted to compile the info for Memphis first as it is the toughest to do.
Share this post
Link to post
King Tut
Awesome. I plan to drop that SpecE30 record lap next time out on some RRs instead of very worn and later flat spotted RA1s.
Share this post
Link to post
Shawn T.
Track Records for MIR updated as of the 2013 Shake & Brake event at MIR
Share this post
Link to post
vpk944
GTS1 now 121.901 on 9/29/13.
Share this post
Link to post
PKM944
Spec 944, 121.620... Race 1 9/28/13 Pat Magruder
Share this post
Link to post
Shawn T.
At this time, we have decided to not honor any track records that were broken while running the hot pits on Sunday. Based on your time from Saturday, you are still the current track record holder at 1:23.331.
Share this post
Link to post
King Tut
Misprint or just two Chris's being equally quick:
PTD Chris Viscovich 1:19.019 9/28/13
Spec E30 Chris Tuttell 1:19.019 9/28/13
Checked the results, the other Chris was quicker than me. I only did a 1:19.097.
Share this post
Link to post
Shawn T.
and I just shredded by Master copy...did you break the record with a 1:19.097? I have another copy at home and will check it then.
Share this post
Link to post
King Tut
It is still a new record yes. I think I only did a 1:19.2 in the Aussie race at the event before last.
Share this post
Link to post
DaDr00
We can still pull the times from Orbits if needed, Shawn. No worries.
Share this post
Link to post
DaDr00
Just for clarification, both of these times were shattered this weekend! But for posterity: Chris Tuttell's time was actually a 1:19.097 in September. I'll update the post after Sunday's times!
Share this post
Link to post
Shawn T.
Updated as of 11/10/2013.
Share this post
Link to post
Brian E.
How bout a rookie with the 944 record! Nice job sir and some good driving during the race.
Share this post
Link to post
AThomas
It looks like it was a good weekend to break a record. For some reason we have two different times showing up for SU. The 1:11.653 is the correct one.
Share this post
Link to post
FD Jeremy
Thanks Brian! I don't think I would've run that fast if I wasn't chasing you. Then again, I would have some more tire money in my pocket if I had left well enough alone.
Share this post
Link to post
King Tut
You will find that once you get out there and there is a carrot in front that it is very hard to back it down even if you already have the class win in hand.
Share this post
Link to post
Rob O
New track record for Honda Challenge today.
Share this post
Link to post
Brian E.
Congrats! And spec e30 too!
Share this post
Link to post
evojim
The records page needs some freshening up. I might have a new TT3 lap record, but I don't know what the old one is/was.
Share this post
Link to post
Shawn T.
After consideration, we have determined that there is no advantage gained by running the hot pits so any track record set when running the hot pits will stand.
All Mid South track records are being updated and will be posted to a new Google spreadsheet for easier management.
Share this post
Link to post
Rick Worth
Hey Shawn, where will the pictures be posted from the weekend when she gets them done? Thanks. Rick Worth
Share this post
Link to post
Shawn T.
They will be posted both here and our Facebook page.
Share this post
Link to post
Dead Horse
I believe TTD should have a new record as well.
Share this post
Link to post
HNBAS
TTE could use an update and I don't even see Spec Miata
Share this post
Link to post
evojim
Ahem......., about that slightly outdated records page
Share this post
Link to post
