Murtz Posted May 14, 2013 Share Posted May 14, 2013 Anyone know if a 1992 Honda Prelude with the following mods would be competitive in HC? Engine: JDM H22 from HMotorsOnline.com (mileage unknown, used for 3 track days) Custom intake and filter modified factory intake manifold custom catch can Walbro 255 lph fuel pump No AC or power steering New brake master cylinder and brake booster new hoses all around new water pump new timing belt w/ H23 manual tensioner removed all unnecessary sensors Electrical: P28 ecu w/ custom tune on Chrome Longacre racing kill switch Braille 9lbs battery in custom lowered tray (regular upkeep with a battery tender) Suspension: Custom rebuilt Koni yellow shocks, rebuilt and shortened by Koni USA Multiple sets of Hypercoil springs: 850, 900, 950, and 1,000 lbs springs (2 of each; 850 and 1,000 on car) Koni adjustable sleeves for springs custom made aluminum isolators on tops of springs SPC camber kits on front and rear (caster & toe stock adjustable front, toe stock adjustable rear) McKinney Raceworks spherical radius rod bushings Hard Race front lca, rear lca, and rear trailing arm bushings (all spherical/pillow ball) Brakes: 96 Vtec brake upgrade in front Carbotech XP10 front pads and XP8 rear pads ATE Super Blue brake fluid Safety: Custom built in roll cage to SCCA and NASA spec by Lucas Automotive Restoration in Houston w/ additional seat bracket for shorter driver; NASCAR syle door bars (full cage cost $3,700 installed) Ultra Shield 16" 20 deg Pro Road Race Seat w/ gray cover- Driver Ultra Shield 17" 20 deg Rally Sport Seat w/ gray cover- Passenger G-Force pull down cam lock 5 point harnesses for driver and passenger Custom adjustable rear seat brace for drivers seat Window net for driver Center net I/O Port camera mount NRG steering wheel and quick disconnect kit w/ working horn I/O Port Heavy Duty Tow Straps - front & rear Quote Link to comment Share on other sites More sharing options...
National Staff Jeremy C. Posted June 6, 2013 National Staff Share Posted June 6, 2013 I believe so. The H22 is a very fast platform and could do very well in HC2! Quote Link to comment Share on other sites More sharing options...
wm577 Posted June 12, 2013 Share Posted June 12, 2013 The prelude can do good in H2. A few things you might want to do down the road to make it faster: Use a S2K throttle body, over the OEM prelude one. It's a little bigger and still legal. Get a good 5 angle valve job done on the head Use stiffer valve springs so you can rev to 8K RPM (H22's can make good power up there with good flowing intake and exhaust) Get a good LSD, and a 4.7 FD or 5.1 FD (depends on your tire size) in the transmission when you get up to speed you might need to get a bigger brake set up. I started cracking the OEM rotors every 3rd or 4th track day (real bad cracks all the way to the other side of the rotor). I went to a 2000 acura RL rotor (larger mass) and it fixed that problem. Good Luck! Quote Link to comment Share on other sites More sharing options...
Lo-bucK Posted June 19, 2013 Share Posted June 19, 2013 the h22 is definitely a strong contender in the h2 class! Quote Link to comment Share on other sites More sharing options...
