Set of four Race Ramp wheel stands. Part number RR-WS-14. New these stands retail for $574.00 plus tax/shipping. Used very little.Very stong and very light unlike the steel versions of these stands. $375 plus shipping for the four. I will ship at cost but prefer a local pickup in the Los Angeles area. to avoid the hassle and cost of shipping.
From the manufacturer web site:
Race Ramps Wheel Stands were created as a replacement for heavy metal wheel alignment stands or Monkey Grease Plate Stands. The concept is clear, the Slip Plate Stand is used usually with a 2 or 4 post lift system. The vehicle is raised on the lift; the Wheel Stands are positioned under each tire with a turntable on top of each stand. Then the vehicle is lowered onto the stands ready for alignment. Typically alignment turntables are used atop most alignment stands.
Race Ramps Wheel Stands are very light and strong. The base is 18 Inches by 18 inches; they have a huge and stable footprint. Using our Patented Race Ramps Technology, these stands are 100% solid core with zero cavities. Every race Ramps products carries this quality, as well. Solid. Though we do not advise it, they can be used on sand.
The horizontal surface is reinforced to ensure your new Wheel Stands will last for many years of commercial use. The beauty of our Wheel Stands, is that you can use them for other applications, such as Car Show display. They are unmarking and will not scratch an epoxy coated garage floor. They also incorporate our "No-slip" Race Ramps technology, They simply do not budge.
