Spec Z Rule Addendum 8-1-13
  • National Staff
8/9/2013
Rule Addendum
Effectively Immediately
NOTE: Underline= Items Added / {Bracket= Deleted items}
14.1 Suspension
D) Front upper control arms (A-Arms) may be replaced with aftermarket components for the purpose of adjusting camber on the front wheels. Factory mounting positions must be retained.
19 NASA National Championship Event
b) NASA will impose a maximum horse power limit for each Spec-Z engine classification.
• Horsepower readings will be measured utilizing a Dynojet Dynometer with the SAE correction factor and smoothing factor of “5”.
• NASA may impound all competitors and require certain competitors to report to the dyno located trackside for dynojet dynometer testing immediately following any on track session.
• Any competitor found to be competing over the allowed maximum horse power limit for their particular engine classification will be disqualified from their previous session unless they are found to have an additional {15lbs} 20lbs for each horse power they are over the maximum limit for the duration of the event.
• NASA may also utilize data acquisition systems to measure real time acceleration rates during competition to supplement the trackside dynometer testing.
  • 2 weeks later...
