JWillis Posted August 21, 2013 Share Posted August 21, 2013 I am going to my first HPDE event Oct 5-6th at Sebring so I've been reading the rules and I'm seeing that the spare tire and jack removal is crossed out but it says "all loose objects in the passenger compartment should be removed". My car is a hatchback (370Z), will the spare tire count as loose objects in the passenger compartment? In my car the factory sub is mounted over the spare so I'm trying to figure out if I should remove it before we go so it's not bouncing around in there. Quote Link to comment Share on other sites More sharing options...
braknl8 Posted August 21, 2013 Share Posted August 21, 2013 I should remove it before we go so it's not bouncing around in there. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted August 21, 2013 Share Posted August 21, 2013 Pull it out, shouldn't be hard to do and it improves safety. Quote Link to comment Share on other sites More sharing options...
JWillis Posted August 21, 2013 Author Share Posted August 21, 2013 Thanks you the reply guys! So are you saying I should take out both the spare and the sub? The reason I ask is because if I leave the spare I need the sub because it screws in on top of the spare to hold it down. Seems odd to me but what do I know? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted August 21, 2013 Share Posted August 21, 2013 pull them both, especially if it's easy ala "a couple screws/bolts and unclip a wiring harness" easy Quote Link to comment Share on other sites More sharing options...
JWillis Posted August 21, 2013 Author Share Posted August 21, 2013 OK will do, thanks again! Quote Link to comment Share on other sites More sharing options...
