1996 Acura Integra
For Sale is my 1996 Acura Integra, it has 135548 on the chassis. The B18C1 GSR motor was rebuilt by Ray’s Performance and Machine Shop in Tampa at 132810 miles. The long list of mods and spare parts is below. If you are interested please call or text, 813-679-0364. My name is Billy. Asking price is $6,500 OBO. Located in Tampa FL.
Current mods:
DRIVETRAIN:
B18C1 swap
Balanced and Blue printed by Ray’s Performance
ACL Race rod bearings
ACL Race main bearings
USDM ITR transmission
JDM ITR Pistons
ATI super damper
Port match one inch in head
Gates Racing timing belt
Z10 block girdle
Moroso 5.5 quart oil pan
Moroso oil pan studs
Moroso oil breather tank
ITR oil cooler
ARP head studs
ARP rod bolts
ARP main bolts
ARP flywheel bolts
ARP clutch plate bolts
Cometic head gasket
Skunk2 intake manifold
Hondata IM gasket
Password JDM carbon fiber intake
RMF Narrow B-series headers
Blox 2.5" cat flange
Hushpower muffler in place of cat
Skunk2 mega power exhaust
Koyo aluminum race radiator
Mishimoto 160 degree thermostat
Mishimoto 180 degree fan switch
Slimfans.com electric pusher fan
ITR Fuel pressure regulator
Delphi 336cc injectors
B&M Short Shifter
Walbro 255lph fuel pump
Exedy Stage 1 clutch
Fidanza 7.5 lb. flywheel
obd2 to obd1 xenocron conversion harness
obd1 vtec ecu built by xenocron Tuned with crome
Rywire ls to vtec conversion harness
Innovative billet motor mounts with race grade bushings
Avid Racing solid torque mounts
SUSPENSION:
Koni Yellow shocks
Ground Control coilover sleeves (550 lb./F - 375lb./R)
Gator Racing axles
Full Race Traction bars
Energy Suspensions poly suspension bushing kit
ITR front strut tower brace
ITR rear sway bar
Blox adjustable end links
Beaks rear sway bar reinforcement kit
Skunk2 Pro Plus front camber kit
SPS rear camber kit
Mugen trailing arm bushings
ARP extended wheel studs
BRAKES:
Fastbrakes.com 11.6 inch front brake kit
Wilwood Dynapro 4 piston calipers
ITR Brake booster
ITR Brake Master Cylinder
Earl’s SS brake lines
Powerslot rear rotor
Wilwood BP-30 front pads
Carbotech XP8 rear pads
Pentosin Racing brake fluid
OTHER:
Carbon fiber hood
Samco radiator hoses
Momo steering wheel and hub
NRG quick release steering wheel adapter
Corbeau FX1 racing seat
Autometer Cobalt Water Temp Gauge
Autometer Cobalt Oil temp Gauge
Autometer Cobalt Oil pressure Gauge
B&M fuel pressure gauge
Odyssey dry cell battery
4 point crow harness
4 point roll cage
Gutted interior
Spare Parts:
2 sests (8) Kosei K1 TS wheels Gray:
15x7 12.5lb
One set has toyo r888 tires with no life left
One set has hoosier cantilever race tires with a couple of events left
OEM hood
OEM drivers seat
Set of rebuilt axles
ITR Front Sway bar with all hardware and bushings
(2) 450lb eibach springs
Ignition Parts:
Cap
Rotor
Ignitor
Coil
Spark plug wires
ITR Brake master cylinder with reservoir
Front wildwood street pads
Starter
Thermostats
Timing belt tensioner
Alternator belt
