wagongotya Posted August 30, 2013 Posted August 30, 2013 1996 M3 Race/Track Car New track car has arrived and it is time to find the m3 a new home. She's incredibly clean and ready to race NASA/SCCA/Club. Build specs and history below: Body/Aero: 2,600lbs (zero factory wiring remains) Lexan front windshield, side windows, rear window OEM fenders Composite fiber hood Composite fiber trunk lid Oem LTW wing Oem LTW splitter (adjustable) Suspension: Moton Clubsport 2-way adjustable dampeners Turner subframe and sway bar reinforcement kit JTD rear and front strut tower braces Racing Dynamics front and rear sway bars TCKline trailing arm monoballs Solid diff & subframe bushings BMW X brace Engine: 3.2L VAC stage one head (ported, Ti valves and springs) CP Pistions H-beam rods Electromotive Tech3R standalone engine management (beautifully installed by Electromotive themselves) Datalogger/dash lcd screen Supersprint headers (with 6 individual EGT's no more burning down cylinder 6) Supersprint exhaust Custom Intake Dual fuel pumps Huge radiator fans/temp controlled (zero heat issues) Drivetrain: Brand new BMW factory transmission JB racing aluminum flywheel ClutchMasters clutch/pressure plate Built 3.64 differential New AKG motor and tranny bushings Interior/Safety: Professionally built 8 point roll cage, nascar doors, rear shock mount towers Halon fire suppression (motor, driver, passenger) Two Recaro Pole Positions race seats with 6 pt. belts Physical gauges for oil temp, coolant temp, and tachometer Full datalogging lcd screen with up to 50 input sources (internal memory) Custom fuse panel in car Custom brake ducting (from front bumper) Center and window safety nets Removable Sparco steering wheel Full headlight and brake light functionality 2 sets of Kosei K1's with Hoosier R6's and RA-1's Quick car history: 1996 BMW M3 street car converted to a SCCA T2 track car by Edva Motorsports in Chicago, IL. Car was purchased from Edva by the previous owner and completely stripped and rebuilt. A new cage was custom fabricated, interior and exterior freshly painted, motor built, transmission replaced, lsd installed, and suspension packed full of goodies. I purchased the car last march with only break in miles on everything listed above...the car has had 4 HPDE events since completion (RA, Blackhawk, BIR, Mid Ohio) and is as clean as the day I bought it. The car has both NASA and SCCA Log books. Link to 100's of pictures: https://plus.google.com/u/0/photos/108768715334287003873/albums/5914008944066510977 Price is $19,000. Please contact me with any questions and thanks for looking! call/txt/email Matt [email protected] 612.597.7011 Quote
