FS:Honda Racers look! ITR :Skunk 2:Samco:Exedy:Zeal:Eibach
All Parts were in perfect working order when they came off the motor. Located in SoCal. Text is best 513 - 4 seven 6- two two 38
Skunk 2 Pro Manifold for PR3 heads and RPM Service 68mm throttle body $350
Exedy OEM replacement clutch and OEM ITR Flywheel. Like new, low miles, springs and keepers in perfect shape, no hot spots, worked perfect at Buttonwillow last month. $125
OEM OBD2a Alternator $30
OEM Starter $old!
OEM Oil cooler and water line: $old!
OEM Rear mount bracket $10
OEM Knock Sensor $20
OEM Thermo switch $5
P73 JDM ITR OBD2a ECU $80
Samco coolant hoses for B16/B18C5 Fitment, coolant temp sensor bung spliced in $35. I also have uncut Blue Silicone non Samco coolant hoses for B16/B18C5 fitment $35
Zeal S6 full aluminum coilover system w/ Eibach ERS 700lb (12.5K) front 650lb (11.5K) rear $900
  • 2 weeks later...
FYI this skunk2 Manifold is LEGAL in all levels of Honda Challenge.
  • 2 weeks later...
Let me see if I can find a buyer for my AMR coilovers (12K/14K) and I'll buy your Zeals.
