Cobra4B Posted September 9, 2013 Posted September 9, 2013 (edited) Buyer pays shipping & paypal fees. Feel free to ask any questions. 2 stock radiators - $100 each *One removed around 100k miles from a 2001, the other came out of an '04 with 15k. Upgraded to a custom race radiator so don't need either. Bumper cove filler close-out panels - $30/pair K&N filter for 4" intake tube - $40 * Brand new never used, includes clamp OEM brake ducts pre-cut for DRM cooling extensions - $10 Passenger Side Air Dam - $5 * Some wear * Driver side sold Nearly new LS1/6 timing cover - $50 GM HD C5 endlinks - $45 LS1/6 cam gear approx 50k miles - $15 2 OEM 192 degree LS2+ tstats - $5 each 1 OEM 192 degree LS1 t-stat - $5 160 degree SOLD 3 sets of LSX rocker arm pedestals - $10/pair 1 sold, 2 sets left. 4 sets of OEM LS1 pushrods. All roll straight on a glass table: Brand new - $20 SOLD Brand new - $20 SOLD Lightly used - $20 100k miles - $15 2nd set C5 front spring adjuster bolts; uncut - $30/pair 1st set C5 front spring adjuster bolts; uncut - $30/pair SOLD 1 set of rear spring adjuster bolts; uncut - $15 SOLD C5 door accordions - $10 C5 passenger door control panel - $10 C5 passenger air bag switch - $10 C5 interior door handles - $20/pair Spindle aka knuckles - $50/pair, $100 all SOLD Torch red front fascia - $50 SOLD Front bumper lower close out panels - $10 each, $20 pair SOLD 1 Motorad 160 degree LS1 t-stat - $20 SOLD Halltech Stinger Intake - $70 SOLD Center air dam with brackets - $30 SOLD Radiator shroud with air temp sensor - $30 SOLD]/b] Radiator cradle - skid bars - $50 SOLD]/b] Pro Dyno C5 Pro Cold twin cone intake - $50 SOLD Stock intake with Z06 lid and Donaldson filter - $50 SOLD Driver side air dam - $5 SOLD 3 timing cover gaskets ALL SOLD Upper and lower radiator hoses - $20 each, $40 pairSOLD Hood shocks - $15 SOLD Upper radiator support mount bracket - $30 SOLD LS6 exhaust manifolds with AIR port block-offs - $75 SOLD LS6 oil pan with windage tray and pickup. Needs a thorough cleaning - $150 SOLD OEM valve covers from a 2001 LS6 (includes oil fill/cap, bolts, gaskets) - $100 SOLD New LS1 springs. Never run - $20 SOLD LS6 valley cover from a 2001 - $50 SOLD 2004 Sachs Z06 shocks with Hardbar delrin upper mounts - SOLD Delrin front spring adjuster bolts - $30 SOLD C5 Z06 springs - $250 SOLD C5 engine mount pedestals - $50 SOLD New LS1 cam from 2004 GTO crate motor. Never run - $50 SOLD OEM LS1/LS6/LS2 rocker arms with bolts. 100k miles. No issues or odd wear - $20 SOLD New 241 heads with springs. Never run - SOLD New LS2 timing chain. Never run - $20 SOLD Brand new LS2 lifter trays - $20 SOLD New 2004-spec LS1/6 valley cover - $50 SOLD Stock LS plug wire shields - $10/set SOLD OEM LS serpentine tensioner - $15 SOLD Stock C5 shifter - $5 SOLD ARP head stud kit for pre-2004 LS1 - $250 SOLD New LS6 exhaust gaskets - $15 SOLD New LS1 lifters. Never run - $20 SOLD 2 new LS1 GTO oil pans with pickup tubes and gaskets. Never run - $100 each SOLD 1 C5 Z06 wheel center cap - $5 SOLD LS1 GTO/Fbody balancer. Never run - $50 SOLD C5 cup holder insert - $5 SOLD OEM LS1/6/2 oil cap - $5 SOLD OEM LS1/6 starter. 100k miles. No issues when removed - $20 SOLD OEM LS1/6/2 rocker arms with bolts. Low miles - $40 SOLD Edited April 17, 2014 by Guest Quote
Cobra4B Posted November 10, 2013 Author Posted November 10, 2013 ttt.... updated with valve covers and valley cover. Quote
Hokie Posted March 31, 2014 Posted March 31, 2014 ttt... added some stuff. Interested in the pre-cut brake ducts and possibly the air damn plastics. Will you be at any of the following events? NASA-NE April NJMP NASA-MA April Summit Point NASA-MA May VIR Quote
Cobra4B Posted April 1, 2014 Author Posted April 1, 2014 ttt... added some stuff. Interested in the pre-cut brake ducts and possibly the air damn plastics. Will you be at any of the following events? NASA-NE April NJMP NASA-MA April Summit Point NASA-MA May VIR I'll be at VIR in May. I just sold the diver side air dam plastic piece. I still have the center air dam and the passenger side one. ~Brian Quote
