rwames Posted September 24, 2013 Posted September 24, 2013 2001 Z28 Rocky Mountain Championship Camaro CHASSIS Penske custom valved 3 way remote reservoir shocks Two sets of springs Global West upper control arms Factory LCA’s with new bushings and ball joints Moog tie rod ends Hotchkiss front and rear 3 way adjustable sway bars With drop links and spherical bushings Heater core block off panel ENGINE NEW 2013 GM LS6 Crate motor Oil cooler, power steering cooler Griffin radiator with custom ducting Kooks stainless steel headers w/ custom Y pipe and muffler Race prepped power steering pump DRIVELINE Custom built aluminum drive shaft Auburn Differential Superior axels with ARP Wheel Studs Timkin front hubs with ARP wheel studs 3:73 and 3:90 gear set. 3:90 installed Aluminum rear diff cover Adjustable panhard bar Corvette front calipers New rear stock calipers Blaine Fab custom front brake cooling ducts B & M shifter 2013 rebuilt and strengthened 6 speed gear box Raybestos brake pads all around ELECTRICAL Re-mapped ECU Heavy Duty master cut-off switch Wired for radio and data module INTERIOR NASA/SCCA cage with drivers side NASCAR bars plus additional strengthening SPARCO Circuit Pro seat with slider (2010) Fire system with 4 nozzles Quick release suede covered MOMO steering wheel 6 point G-Force cam lock belts Hinge mounted window net Factory dash with custom insert for ACCUTECH gauges EXTERIOR Front custom ABS splitter ( you can stand on it) Enlarged nose opening with custom ducting VFN superlight fiberglass hood with six hood pins GT Racing rear wing with Blaine Fab custom uprights Four Corvette 17” X 9” racing wheels Four CCW custom 3 piece wheels with TOYO 275/45/17 RA1 shaved to 4/32, 5 heat cycles Front and rear tow hooks Car was originally built by Phoenix Racing and was Mike Pettifords T-2 Championship car Race car since new 20731 total miles $29,500.00 Robert Ames 970-846-9070 [email protected] Quote
