97 VD/FC Project car,spares, and 22' trailer $16.5k
Of the responses I have had the most asked question is what does going thru
mean?
What I was planning on doing to the car:
1) First I was going to take the engine out and check the bottom end and
have the head reworked and purchase the latest cam, and flywheel. The
previous owner said the clutch was new. And depending on what the
bottom end looks like may go ahead and replace bearings and rings.
2) I was going to check the master cylinders ( previous owner said they
were new ) and make sure they were. Then I have rebuild kits for the
calipers and I was going to do that. The braided lines for the brakes are
brand new so that won't be an issue.
3) I was going to do some checking on the different things about the
wiring ie: any wires not needed or things that I didn't care whether
it was on the car and then install the new ignition system. Which I have
as a spare. Then of course tidy up the wires.
4) Look at all the hiems ( previous owner said he had just changed them
all out ) and make sure they all were OK.
5) Change the fluid out for the tranny
6) Put the zsus fasteners back in the bodywork then put on the new numbers
and any striping that I might want.
7) Put the slicks with only one session on the current wheels and she should
be ready for the track
I have it listed on the Alabama SCCA website and there are several photos
there for veiwing as well. http://www.alscca.net/community/showthread.php?t=3844
Thanks,
John Newcomb
