Vettedoctor Posted October 16, 2013 Posted October 16, 2013 I was talking with another ST racer and he sent me this simple classing structure New ST1= ST1 rule set at 5.5 to 1 and STR1 rule set at 5.75 to 1 New ST2= ST2 rule set at 8.0 to 1 and Bring back the STR2 rule set and run at 8.25 to 1 New ST3= ST3 rule set at 9.0 to 1 (non-aero) and ST3 rule set at 9.5 to 1 (with aero) and STR3 rule set at 9.75 to 1 So yeah combine ST and STR cars but with a .25 modifier (this number could be changed at any time if it needs to), if anything try it regionally so we can see what happens to car counts, if they don't back to the drawing board. Just another idea (actually it's a couple of your ideas put into one post). Quote
kbrew8991 Posted October 16, 2013 Posted October 16, 2013 I was talking with another ST racer and he sent me this simple classing structure New ST1= ST1 rule set at 5.5 to 1 and STR1 rule set at 5.75 to 1 New ST2= ST2 rule set at 8.0 to 1 and Bring back the STR2 rule set and run at 8.25 to 1 New ST3= ST3 rule set at 9.0 to 1 (non-aero) and ST3 rule set at 9.5 to 1 (with aero) and STR3 rule set at 9.75 to 1 So yeah combine ST and STR cars but with a .25 modifier (this number could be changed at any time if it needs to), if anything try it regionally so we can see what happens to car counts, if they don't back to the drawing board. Just another idea (actually it's a couple of your ideas put into one post). :like: class consolidation and it makes decent sense too! Quote
ILIKETODRIVE Posted October 16, 2013 Posted October 16, 2013 I was talking with another ST racer and he sent me this simple classing structure New ST1= ST1 rule set at 5.5 to 1 and STR1 rule set at 5.75 to 1 New ST2= ST2 rule set at 8.0 to 1 and Bring back the STR2 rule set and run at 8.25 to 1 New ST3= ST3 rule set at 9.0 to 1 (non-aero) and ST3 rule set at 9.5 to 1 (with aero) and STR3 rule set at 9.75 to 1 So yeah combine ST and STR cars but with a .25 modifier (this number could be changed at any time if it needs to), if anything try it regionally so we can see what happens to car counts, if they don't back to the drawing board. Just another idea (actually it's a couple of your ideas put into one post). :like: class consolidation and it makes decent sense too! Ditto. Quote
Bnjmn Posted October 16, 2013 Posted October 16, 2013 This is what I have been proposing, so I am all for it. I was talking with another ST racer and he sent me this simple classing structure New ST1= ST1 rule set at 5.5 to 1 and STR1 rule set at 5.75 to 1 New ST2= ST2 rule set at 8.0 to 1 and Bring back the STR2 rule set and run at 8.25 to 1 New ST3= ST3 rule set at 9.0 to 1 (non-aero) and ST3 rule set at 9.5 to 1 (with aero) and STR3 rule set at 9.75 to 1 So yeah combine ST and STR cars but with a .25 modifier (this number could be changed at any time if it needs to), if anything try it regionally so we can see what happens to car counts, if they don't back to the drawing board. Just another idea (actually it's a couple of your ideas put into one post). Quote
z06tracker Posted October 18, 2013 Posted October 18, 2013 This is not even close to solving the problem. It will make little difference in class car counts on any given weekend. This is what I have been proposing, so I am all for it. I was talking with another ST racer and he sent me this simple classing structure New ST1= ST1 rule set at 5.5 to 1 and STR1 rule set at 5.75 to 1 New ST2= ST2 rule set at 8.0 to 1 and Bring back the STR2 rule set and run at 8.25 to 1 New ST3= ST3 rule set at 9.0 to 1 (non-aero) and ST3 rule set at 9.5 to 1 (with aero) and STR3 rule set at 9.75 to 1 So yeah combine ST and STR cars but with a .25 modifier (this number could be changed at any time if it needs to), if anything try it regionally so we can see what happens to car counts, if they don't back to the drawing board. Just another idea (actually it's a couple of your ideas put into one post). Quote
ILIKETODRIVE Posted October 18, 2013 Posted October 18, 2013 This is not even close to solving the problem. It will make little difference in class car counts on any given weekend. Quote
Cobra4B Posted October 18, 2013 Posted October 18, 2013 This is not even close to solving the problem. It will make little difference in class car counts on any given weekend. This is what I have been proposing, so I am all for it. I was talking with another ST racer and he sent me this simple classing structure New ST1= ST1 rule set at 5.5 to 1 and STR1 rule set at 5.75 to 1 New ST2= ST2 rule set at 8.0 to 1 and Bring back the STR2 rule set and run at 8.25 to 1 New ST3= ST3 rule set at 9.0 to 1 (non-aero) and ST3 rule set at 9.5 to 1 (with aero) and STR3 rule set at 9.75 to 1 So yeah combine ST and STR cars but with a .25 modifier (this number could be changed at any time if it needs to), if anything try it regionally so we can see what happens to car counts, if they don't back to the drawing board. Just another idea (actually it's a couple of your ideas put into one post). Will it instantly increase car counts in MA? No. But I guarantee it will pull some of the folks that got screwed by STR back out on track. It will create simplicity which will allow the class to start gaining some momentum again. It's the proper first step. Quote
Falcon Posted October 18, 2013 Posted October 18, 2013 I don't think we even have to apply a modifier to the STR cars. They haven't demonstrated in all cases a huge disparity in track times directly attributable to frame advantages since there aren't that many running. Bring them in even with the ST's. If later they show an advantage, modify them then. I think we're letting the perfect (ruleset) be the enemy of the good (ruleset). Let the Panoz's, etc. run with the ST groups and let's see what happens. Quote
topmover1 Posted October 18, 2013 Posted October 18, 2013 http://thenaturalparadox.files.wordpress.com/2012/03/negnan.jpg How do some of you guys come up with this stuff...............thanks for the laugh Quote
Cobra4B Posted October 18, 2013 Posted October 18, 2013 I don't think we even have to apply a modifier to the STR cars. They haven't demonstrated in all cases a huge disparity in track times directly attributable to frame advantages since there aren't that many running. Bring them in even with the ST's. If later they show an advantage, modify them then. I think we're letting the perfect (ruleset) be the enemy of the good (ruleset). Let the Panoz's, etc. run with the ST groups and let's see what happens. I agree with this... KISS. There aren't any readily available tube chassis cars that have an inherent advantage over a well prep'd Viper/Vette etc. Quote
z06tracker Posted October 18, 2013 Posted October 18, 2013 I agree 100 percent. I would love to see this, but I also think more class consolidation is necessary. I don't think we even have to apply a modifier to the STR cars. They haven't demonstrated in all cases a huge disparity in track times directly attributable to frame advantages since there aren't that many running. Bring them in even with the ST's. If later they show an advantage, modify them then. I think we're letting the perfect (ruleset) be the enemy of the good (ruleset). Let the Panoz's, etc. run with the ST groups and let's see what happens. Quote
jason Posted October 18, 2013 Posted October 18, 2013 I don't think we even have to apply a modifier to the STR cars. They haven't demonstrated in all cases a huge disparity in track times directly attributable to frame advantages since there aren't that many running. Bring them in even with the ST's. If later they show an advantage, modify them then. I think we're letting the perfect (ruleset) be the enemy of the good (ruleset). Let the Panoz's, etc. run with the ST groups and let's see what happens. This Quote
National Staff Greg G. Posted October 21, 2013 National Staff Posted October 21, 2013 I don't think we even have to apply a modifier to the STR cars. They haven't demonstrated in all cases a huge disparity in track times directly attributable to frame advantages since there aren't that many running. Bring them in even with the ST's. If later they show an advantage, modify them then. I think we're letting the perfect (ruleset) be the enemy of the good (ruleset). Let the Panoz's, etc. run with the ST groups and let's see what happens. This No.....This viewtopic.php?f=18&t=107871 Quote
National Staff Greg G. Posted October 21, 2013 National Staff Posted October 21, 2013 I don't think we even have to apply a modifier to the STR cars. They haven't demonstrated in all cases a huge disparity in track times directly attributable to frame advantages since there aren't that many running. Bring them in even with the ST's. If later they show an advantage, modify them then. I think we're letting the perfect (ruleset) be the enemy of the good (ruleset). Let the Panoz's, etc. run with the ST groups and let's see what happens. I agree with this... KISS. There aren't any readily available tube chassis cars that have an inherent advantage over a well prep'd Viper/Vette etc. Right, and if the rules were opened up so there were no body, chassis limitations, nobody would do anything to their currently well prep'd Vipers/Vettes. Or, rather, nobody would build one starting with a cheap old car, using every available mod, including partial tube frame conversion and completely re-worked suspension geometry, etc. Ok, so you think that the guys who decide to take advantage of the new "open" rules that then are told in a year that they now have a new 0.X Mod Factor applied to their car because of XYZ mod that cannot be reversed are going to stay with the series and NASA, or will they just give up? Many of us would like to merge these classes, but regardless of how it is done, someone is going to end up unhappy. If we go with a direct merge, it will be a huge change to the ST Rules that will be very costly for those who want to be on top. If we go with a Mod Factor and essentially delete the STR classes, then those that are in STR that are already getting beat by ST cars will complain that they are already slower than the ST cars and we just added more weight/less power to their setup. So, KISS cannot apply when it is not a simple issue. But, we continue to work on this! Quote
ILIKETODRIVE Posted October 21, 2013 Posted October 21, 2013 (edited) Ok, so you think that the guys who decide to take advantage of the new "open" rules that then are told in a year that they now have a new 0.X Mod Factor applied to their car because of XYZ mod that cannot be reversed are going to stay with the series and NASA, or will they just give up? I would hope not. If someone beats me in qualifying and gets to Turn 1 during the race before me, I don't just throw in the towel and say, "Well, that's that." No. I keep fighting. It's racing. But hey, maybe that's just me. Edited October 21, 2013 by Guest Quote
kbrew8991 Posted October 21, 2013 Posted October 21, 2013 Alternative: Regionally - don't allow regular ST as an option, re-add STR2, and have people regionally run STR1,2 or 3. Nationals - keep them split for now so long as car counts are good enough Were I a regional ST director, that's what I'd try and get my guys to do anyway... Quote
brkntrxn Posted October 21, 2013 Posted October 21, 2013 That works the other way as well for STR1 and STR3. Just move to those classes and run in them.... Except when the STR3 cars are small and they run in the Lightning group and no one will let you bring your monster sized plastic C5 to play with the "slow" cars. I understood the reasoning, just thought it was unfair to be blocked from running in a class in which I could. Quote
hakeem Posted October 21, 2013 Posted October 21, 2013 If we go with a Mod Factor and essentially delete the STR classes, then those that are in STR that are already getting beat by ST cars will complain that they are already slower than the ST cars and we just added more weight/less power to their setup. So, KISS cannot apply when it is not a simple issue. Can't these STR cars that are already slower than ST cars simply drop down a class? How many cars are we really talking about nationwide? With all due respect, constantly working the rules around to accomodate edge cases or to satisfy very small minorities is never going to be a path to any serious growth. Make the most logical changes and continue to modify and accomodate as things shake out. Quote
Vettedoctor Posted October 21, 2013 Posted October 21, 2013 That works the other way as well for STR1 and STR3. Just move to those classes and run in them.... Except when the STR3 cars are small and they run in the Lightning group and no one will let you bring your monster sized plastic C5 to play with the "slow" cars. I understood the reasoning, just thought it was unfair to be blocked from running in a class in which I could. This is a good point Kevin, in the past we would see that the Thunder Roadster guys running STR had absolutely no interest in running with ST cars. Sometimes they would jump into other classes to get away from us and I can't blame them 1500 lbs vs 3200 lbs is kinda rough. So if a blend were to happen what would these guys do? History has shown that they have no interest in running with ST cars, they went to STR because it gave them a place they could run with each other without bigger cars to worry about. I highly doubt that they will stick around if the classes were combined. Quote
Cobra4B Posted October 21, 2013 Posted October 21, 2013 Then make Thunder Roadster it's own class and let them run with Lightning or whatever group they already run with. Quote
brkntrxn Posted October 21, 2013 Posted October 21, 2013 (edited) Then make Thunder Roadster it's own class and let them run with Lightning or whatever group they already run with. Already the case in the Southeast. At 5-15 entries at the typical event, it is hard to fault them for doing so. Edited October 21, 2013 by Guest Quote
mhoward1 Posted October 21, 2013 Posted October 21, 2013 Then make Thunder Roadster it's own class and let them run with Lightning or whatever group they already run with. Already the case in the Southeast. And it works well with 20+ car TR races. Quote
kbrew8991 Posted October 21, 2013 Posted October 21, 2013 the Texas TurdRoasters don't seem to mind running with real cars / real STR3 cars...??! Quote
John Graber Posted October 21, 2013 Posted October 21, 2013 So what does everything think about Torque? Today it is free. A wise and well funded racer will build a torque monster. I've seen this in only about 25% of the cars where they have Torque far outpacing HP. For reference, GTS averages Tq and HP if Tq is higher. Does that fix it? Not really, as it now focuses on tuning. Now imagine a 320HP ST2 car. 320HP 310Tq peak 320HP 470Tq peak 320HP 320Tq flat Hmmmm Quote
J.R. Smith Posted October 21, 2013 Author Posted October 21, 2013 John, If you can afford to build a 320 HP 470 Ft Lb torque car then your 15:1 compression 427 cu in monster or your diesel pusher wins. Torque has not necessarily been an issue so far in ST. I realize someone can always build a better or faster car with enough $ but Scott Tucker is now racing LeMans. There is always a situation where cubic dollars wins but generally I think too many rules tends to kill participation. Look how quickly NASA has grown and SCCA dwindled with a simple solution for racers. I think the "Pfadt car" is a very good example of a well developed high torque car but I think it can be competed against. J.R. Quote
