2001 Mustang Cobra NASA American Iron race car/fresh 347
2001 Mustang Cobra American Iron race car for sale. Super nice car with all the right parts. Recent motor swap to pushrod 347 stroker from Fordstrokers w/ Canfield 192cc heads. Here is a list of the parts:
Maximum Motorsports Kmember and forward offset front control arms
Maximum Motorsports Bilstein MM3 front coil over struts with 2 weekends on them
Maximum Motorsports offset steering rack bushings
Maximum Motorsports IRS Delrin bushing kit w/ diff bushings
Maximum Motorsports Bilstein MM3 rear coilover shocks for IRS w/ 2 weekends on them
Steeda Cobra R front splitter w/ splitter tray (removable)
Ford Racing ABS from FR500S
Sparco Ford Racing Circuit Pro seat
Sparco steering wheel w/ Woodward quick release
Full Cage/1.75 DOM tubing w/ logbook #
Accusump 3qt.
Mocal pump-Rear diff cooler
373 rear gear set
Brembo 4 piston front calipers w/ 2 piece DBA rotors
Mishimoto aluminum radiator w/slim double fan (160 degree water temp when on)lifetime warranty
Canton remote oil filter
Oil cooler
Front and rear sway bars
03/04 steering rack
Aluminum driveshaft (The Driveshaft Shop) balanced
Quartermaster 7.25 double disc clutch
Quicktime bellhousing
T56 road race transmission (carbon fiber blocker rings/Viper kit w/ big shaft)
Torsen LSD
Anderson Ford Motorsport PMS
MSD Digital 6AL ignition
KRC front serpentine kit with power steering pump and denso 75amp alternator
BBK ceramic long tube headers 1 5/8 into H pipe and dual side exhaust
high flow fuel pump
Aeromotive fuel pressure regualator
KRC 100mc fuel filter (cleanable)
Return fuel system w/ braided lines
Helmet blower
Enkei RPF1's w/ Toyo RA1 shaved tires w/ 2 weekends
G Stream Comp 800 Carbon fiber wing w/ struts
Motor: 347 Stroker from Fordstrokers
Zero balance, 10.5 to 1 compression (pump gas), ATI balancer, Dart 4 bolt main block, forged internals w/ ARP 2000 bolts, Canfield 192cc heads w/ new Comp springs (151 lbs. seat pressure), Scorpion roller rockers 1.72, Comp Pro Magnum lifters, Comp push rods, Stainless valves, Double roller timing chain, Melling blueprinted standard volume oil pump, Edlebrock Performer RPM II intake w/ BBK 70mm throttle body, 42lb fuel injectors, Edlebrock fuel rails, Pro M maf 42lb, MSD Pro Billet distributor, MSD spark plug wires w/ heat shields, Aluminum valve covers w/ baffles and remote blow off tank.
Break in was 20 minutes at 2000 rpm's w/ Rotella oil.
Valvoline Race Oil 10w30 w/ zinc used since then
Break in Dyno results were 389 rwhp and 371 rwtq
De-tuned to 351 rwhp and 350 rwtq for legal AI tune at car weight of 3360 lbs. w/ driver and fuel (driver weight 225 lbs.)
Just spent over $11,000 on the motor swap
Spares include 2 sets of wheels (4 Enkei rpf1's w/ Toyo RA1's mounted and 4 Cobra R's w/ Toyo RA1 full tread rains) (cost new over $4,000)
Brand new Hawk DTC 70's for the front Brembo's
Brand new Hawk DTC 60's for the rear brakes (both sets of pads were $375)
Brand new painted Cobra front bumper ($700 w/paint)
Brand new painted Steeda Cobra R front splitter ($800 w/ paint)
Spare 1 piece rotors Powerstop
Spare MSD wires
READY TO RACE!!! Jack Hidley from Maximum Motorsports helped with the set up including spring recommendations. You will not be disappointed.
Car turned a 121.3 @ Summit Point in April
$24,500 for everything.
Cell 978-265-9775
  • 3 weeks later...
  • 5 months later...
Car still for sale. Open to realistic offers near sale price.
978-265-9775
  • 3 months later...
