corvette 2007 Z06 Track car ST1 or SPO for 65,000 new engi
New Engine less then 1000 miles
Engine
LS7 GM Aluminum Block– Callies Compstar Long snout Dry Sump Crank-Lunati Pro Comp Billet 6.125 rods– 58 tooth reluctor wheel-Diamond –4 cc pistons– Total Seal Moly Rings– ZR1 modified oil pump with 30 percent larger scavenge gear- New GM Timing chain and gear LS7– Block set to zero deck– rotating assembly fully balanced
LS7 CNC 265cc ported cylinder head. Fully CNC ported LS7-based cylinder heads! (All New GM LS7 Cylinder Head Castings– Dual spring– complete with valves—port matched to other head– Head gaskets and ARP head studs
Machine shop service and engine assembly
Disassemble and clean Intake manifold and reassemble
Remove Sump tank clean and modify for increased capacity 11 quarts
Replace 2 oil coolers with newer larger capacity coolers
Cylinder Head Avaid Scavange cylinder head mounted pump system
Oil breather system welded to sump pump
Aeroquip 12 an and 10 an lines for scavenge pump with fittings
Labor for engine R and R and full retune
SS Hollow stem race valves exhaust 8
Comp cams #24234
GM Water pump
Rocker arm roller bearing mod
SS Race Valves custom LS7 Exhaust Next day air shipped
Ferrea Racing dual springs
Dewitts aluminum radiator
Clutch:
ZR1 dual clutch system
Brakes:
CCW Rims
Michelin Racing Slicks
Brembo GT brakes front and rear
Hawk DTC70 pads
6 Point race roll cage from Racecar Builders
Cobra race seat
6 point seat harness
Automatic Fire system
Roof Scoop
Body:
Vented front fenders
Front winglets
BPP rear 2 tip diffuser
Rear AeroMotion Carbon Fiber Race Wing
Front Carbon Splitter
Suspension
Pfadt Coilovers with custom springs
Pfadt Comp Swaybars
SCCA- NASA and FARA approved with logbooks
Seller Phone Number: 9546588228
