94 Mustang Track /street car roller
I am putting my Open track mustang project car up for sale...
Body
Very clean 94 stang with a really nice black paint job, Steeda type cowl hood, Steeda rear wing, interior was stripped in readiness for a full roll cage but never got around to buying it, i have a auto power 4 piont bolt in that comes with it. I do have all of the interior except for the 2 front seats its a nice black interior. 96 tail lights
Sub frame connectors, comes with a aftermarket ureathane cobra front bumper with a splitter moulded in not painted or installed yet
Suspension
Front
MM caster plates
Tokicko blue struts with coil over kit spring rate unknown
Griggs tubular crossmember
Griggs extream duty tubular hiem jointed lower control arms
Cobra front sway bar
Rear
MM HD torque arm with the correct TA springs
MM tubular lower control arms
MM partial adj rear sway bar kit (missing the body brackets)
MM Bilstien shocks the ones that can be used with the coil over kit
Brakes
SS Force 10- 4 piston calipers and slotted rotors up front
SS brake lines
Stock GT disc brakes out back
Rear
3.73 posi
Wheels
Ford 17x 9 real Cobra rims with 275 40 17 street tires painted red
Note
The car still has the 347 stroker motor with trck flow heads, rr, canton rr pan, vic jr anf 750 carb attached to a TKO 600 tranny and 3'' aluminium d/s still installed this could be worked into the deal if needed but as of now they will be removed and the car sold as a roller.
So with No motor , radiator or tranny I would like $4500 for the roller OBO
Thank you Barry 631 504-1440 located on Long Island NY
here are some pics of when it was in street trim before i pulled the interior
